Solar Power for my trailer
Started by donpearsall, August 09, 2011, 10:27:02 PM
donpearsall
I am just following up on this project. Four years later the solar panels, solar controller, AC/DC converter, and even the battery are still working 100%. The battery always has  a charge. I did make the mistake of leaving the lights on for several weeks while I was gone and the battery was very low, but not drained. Once I turned the lights off, the battery has had 12.5v all the time.
I see that four years later the Harbor Freight solar kit is still the same price - about $150 with the 20% off coupon you can get anywhere.
BasementBorn
I have seen those kits before and thought about trying one out. I picked up one of the small battery tender ones from harbor freight to hook to my battery on the bike when needed on the salt just to try it out. The thing I was wondering about on yours is how does it do over the winter in WA? I park my trailer outside in the winter and the dang thing is always green come spring. Any issues as far as that is concerned?
Gabe Gorton
Gorton Racing 1060 650APS-BG
Team Banana 1361 F/CPRO
donpearsall
No issues at all with keeping the battery charged during winter. But I hardly use the battery power except for turning the lights on and off. Every once in a while I turn on the DC/AC converter to see if that works. It has no problem powering tools like saws, grinders, work lights.
Nice job on the install Don.  :cheers: :cheers:
Of note is that now there are much better places to buy panels and controllers than Harbor Freight.  For Instance I've bought all my panels for both boats, 560 watts on one and 480 watts on the other from Solar Blvd....
https://www.solarblvd.com/index.php?cPath=1_25_42
and you could get a 40 watt panel from them for $58  ....
https://www.solarblvd.com/product_info.php?cPath=1_25_40&products_id=1401
and a PWM controller for $50....
https://www.solarblvd.com/product_info.php?cPath=6_48_100&products_id=191
The controller above could work with up to a little over 175 watts if you wanted more.
You could get the controller and a 100 watt panel for less than the HF 45 watt system.
Other reputable sellers have pricing similar to Solar Blvd.
