getting salt out of electrical components...
Started by entropy, September 26, 2011, 08:44:50 AM
WOODY@DDLLC
Vinsky
I've used ultrasonic cleaners on just about everything from electronics to gears. With the correct solution, I'm sure it would clean salt out of almost anything.
JamesJ
Quote from: firemanjim on September 26, 2011, 01:35:54 PM
If you are looking in the US for 12/34, it is called 769,same product number,37341.
Is it the same, they have both the 12/34 and the 769 on the webpage? With different part number.
http://www.jetlubecanada.com/pages/1234.html
http://www.jetlubecanada.com/pages/769.html
The corrosion gremlins strike at the most inconvenient times.  Everything seems OK and a person thinks all salt corrosion problems are solved, and then things go wrong.  Often this happens during a meet when it is difficult to diagnose the problems.  It is a good idea to take an extra set of electrical and ignition parts with you to the salt.   I take the stock parts I removed when I upgraded to racing components, including an extra wiring harness.  This make troubleshooting easy.  Simply substitute parts until the problem goes away.
Dean Los Angeles
Explain how you are going to remove the salt from this?
4-barrel Mike
Dean, you obviously didn't use dielectric grease  :mrgreen:
entropy
You guys are providing some very useful info.
Thanks a million!
Karl
JamesJ
jww36
JamesJ;
I'm a land speed racer, and have a metal fabrication shop. I am also the high performance distributor for Armite Lubricants, the maker of 12/34. As I mentioned in an earlier blog, Jetlube Canada is the Canadian distributor for Armite Lubricants and 12/34. The lubricant mentioned in the Grainger catalogue is not 12/34 and is a 12 OZ can. 12/34 is a 14 OZ. can, and if anyone is interested, I will be more then happy to be price competitive with the other stuff. While I don't expect all land speed racers to be loyal and helpful to one another, although I try to be, I would think land speed racers would be loyal to this website. As I mentioned earlier, any sales of 12/34 through Landracing.com will result in my donating a portion of  sales to this website. Will Grainger do the same?
John -
Thanks for your reply and the explanation of your relationship to the 12/34 product.  I'll say this again to all -- you, of course, and the many folks that keep an eye on landracing.com and The Forum to attempt to prevent commercials from interfering with our important stuff -- racing.
I don't object to your comments about selling the 12/34 since you aren't blatantly advertising, since you offer a "competitive" price, and because you offer to send a portion of any sales generated through this forum to landracing.com.  Yes, you're kind of on the edge of what's okay and what's not - such that if you wanted to seriously hawk your wares I'd ask you to pay some $$ and in return get some dedicated advertising.
But -- you ain't, so I won't.  Thanks for your support and help about this stuff.
jww36
Jon;
I'm still trying to get my financial feet back under me after my first Speedweek. If I can just get a few Land Speed Racers to see how great this product is, I will be more than happy to advertise with you. Since I got into Land Speed Racing, and decided to build my own roadster, I can't tell you how much this site has helped me, and I have met some great people.
JamesJ
An earlier post said that the 12/34 and the 769 were the same, I did not think so but some places list the same part number, If I cant get the 12/34 here in town I may see about getting some from you to try out, I currently use Gibbs but this seems to be a bit different.  Another good product to have.  Thanks,
jimmy six
The best advice noone here takes is not to go to Bonneville.......Well I tried.................See you all in a week if your going...JD
entropy
#28
well it seems that jww36 and his rec on Armite 12/34 is on the money.
After getting my evil handling Busa back from WOS, i pulled it down to a motor roller to take to Mackie in LA for frame alignment checking.
(turned out the swingarm was 3/8" bent to left)
Hosed the motor roller thoroughly with water, then sprayed it liberally with 12/34.
Then LIBERALLY sprayed all the wiring & electrical components with 12/34 paying particular attention to connectors & sleeves.
2.5 mo later no trace of corrosion whatsoever, none.   :cheers:
Shoulda sprayed my tools & the fittings in my trailer... :-o
Karl
Koncretekid
Can I get a barrel of it?  I'm thinking:
     1.)  Rinse bike (or car) thoroughly with water, preferably at Miller Raceway where they have a "firehose" size wash station.
     2.)  Remove tires and seat.
     3.)  Immerse entire vehicle in 1234
     4.)  Blow dry
Seems like that should do it.
