How do I link 2 engines rotating in reverse?
Started by TheSteelMan23, October 23, 2011, 09:44:23 AM
Mr411Fan
Correction, I should have said ring gear on the opposite side of the pinion.
Bob Drury
#31
  As strange as this sounds, If my memory is correct Tommy Ivo's twin engine Buick powered dragster ran with the flywheels intermeshed, or maybe I am having another flashback..........
                                                           Bob
Bob Drury
I have the same memory Bob, and my memory's only slightly older than yours. I'm sure we're right! :-D :-D :roll:
Graham in Aus
It's a long thread, but this guy:
http://www.jalopyjournal.com/forum/showthread.php?t=533613
Has joined two via the flywheel starter ring gears!
Lots of info here!
Cheers  :cheers:
desotoman
Quote from: Bob Drury on October 27, 2011, 09:41:14 PM
                                                           Bob
I don't know about Ivo's car, but I do know the Twin Bears Howard's car was that way.
Photo courtesy of Hot Rod Magazine.
RichFox
It's been a long time, but as I remember the Hayward Head Hunters car it had Cadalic engines. And of course I remember the Bustle Bomb as having a Flathead in front and a Chevy six in back.
John, thats a great web site of two to go cars.
4-barrel Mike
Quote from: desotoman on October 28, 2011, 12:20:55 PM
                                                            Bob
Howard's Cams Twin Bears Digger - Twin Bears - Hot Rods
Avoiding one major hassle of re-creating the car was that Donnie still had the coupler to mount a flywheel to the front of the lefthand small-block, which is turned around backward. The engines mesh together at this point, and a clutch is attached to the right-side engine.
Check out the picture here: http://www.hotrod.com/featuredvehicles/hrdp_1008_howards_cams_twin_bears_digger/photo_08.html#ixzz1c7lClxxg
Crazy stuff!   :cheers:
Kato Engineering
It is well documented that IVO had a side by side dual where one was blown and the other was injected.
obviously the injected unit was the reverse rotation engine setup
they were positioned "normal " and coupled at the flywheels.
BHR301
#40
Kato Engineering..Not sure where you got your information but the Ivo twin was injected only, none of his multiple engined cars were blown.
Kato Engineering
should have seperated the two statements..
it is well documented that Ivo had the side by side car.
I do remember seeing a photo on another site of a side by side that one was blown and other was injected..
it might have been on H.a.m.b.
maybe stan fox remembers this  posting  from a couple of years ago
John Burk
In the early 1960s a guy from NJ put together a street roadster with a pair of stock 327s mounted one behind the other . It ran 138 at the drags and he drove it to and from the strip .
kiwi belly tank
The Herbert-Steen 4 engine liner has a reverser box in the middle between # 2 & 3 engines. The front two engines face rearward & the rear two engines face forward with a B&J & a clutch at each end. The system worked well with 2100 cu in making 6000hp.
if that thing had 6000 hp and it worked well what was the problem  :?
