SFI 38.1 and reclined seating position
Started by Jon, November 13, 2011, 02:29:01 PM
Bob Drury
#15
  Not having yet recieved my 2012 rulebook to review, I can only say that if it is written that way it is certainly "one ambiguous rule".
Bob Drury
Cajun Kid
Quote from: Jon on February 09, 2012, 10:08:59 AM
In Aus it needs to be SFI, so choosing from the SFI list is the only option.
Have been in contact with DJ for a while re buying a unit when it was SFI approved, doesn't sound like its happening.
Dont think the HANS units would work, the bit sticking up the back would be a bear & they dont make a unit anywhere near 60 degrees.
I sent an inquiry to Simpson & got this reply:
      "Your best option would be the Hybrid Pro.
       This device does not require your seat to be at any certain angle.
       It will strap to your body and use the belts to protect you."
Cheers
Simpson bought Safety Solutions last year.  Yes the Hybrid Pro or Pro Rage will work very well in a reclined position.
Good luck
Charles
ECTA Record Holder Maxton
OHIO
B/CGALT, C/CGALT
Yep, as long as you have room to put clearance hole or recess in your seat back for the hard collar, if you have a lay down.  Otherwise the hard collar will hold your neck in the perfect position to break it....
YEMV
Thanks guys, I'm just about about ready to start welding bits together.
Buying all the protective gear that I'm going to use so that the seat is made to suit.
Cheers
Dynoroom
#19
Stainless you're mistaken (I think) about the Safety Soultions device (now owned by Simpson). They make several and I think you're speaking about the Rage or R3. The Hybrid Pro is what we use and it does not have the beam that travels down the back.
Our seat lays back only 45 degrees but the kids have no issues with ingress or egress.
Dyno,
Maybe, We tried on or looked at a couple of devices, Sumner had a Hybrid  :? I think (looked a little like the device in your pictures) that the smallest and  we tried in the Bockscar.  It was a small hard collar piece that seemed to just put a hard lump in the back of your neck and hold your head and neck at a bad angle in our seat.
There is another person on the site with a laydown that said they cut a hole or formed a large dent for the device, I remember the discussion but not the thread it was in.  That plan was not possible in our seat.  There is not a lot of room for head movement anyway, your chin and helmet are on your chest.  I think almost any device in this situation is eyewash but the DJ device is the least bulky and will not allow your helmet to roll forward through your chest if that is possible.  Our exit was not an issue.
Cajun Kid
You do NOT need to recess the seat or use a special seat pad for what I was talking about.
Look up the differant models.
Good luck
Charles
OHIO
B/CGALT, C/CGALT
Charles, not starting a pissing contest but what lay down car did you wear any of those devices in?  The Hybrid Pro looks like the device I remember trying.  It might work fine in a reclined position of say 45 degrees, that's a lounge chair.  but in a 15-20 degree that just raises your sholders a little it pretty much sucked.  As I said YEMV (your experience may vary)
Bob Drury
  Jeez. I thought a YEMV was a Czech or Hungarian car......................
  Now this may sound crazy but lets say you didn't need to tilt your head to see.  Would that allow the use of a standard Hans or Hybrid?
  What I am talking about is using a front forward mounted camera and putting as large of a t.v. screen as possible under the canopy.
  It couldn't be any harder to see forward with than "Portland" Charley Markleys 265 mph belly tank which he steers with a periscope showing him where to aim it.
Bob Drury
McRat
Quote from: Bob Drury on February 10, 2012, 09:38:15 PM
Just file a flight plan and drive by GPS alone.
I swear most the drivers on the 91 fwy are already doing it, but their flight plans were rejected ...
Bob, we see all the sky there is out there.... it's the ground and horizon that makes it a challenge...
A lot of your "butt feel" is lost when lying on your back anyway.... I know looking through a periscope really has to add to the "experience"...  I can't imagine...  :roll:
Forgot to add... hope he has crosshairs...
Quote from: Stainless1 on February 11, 2012, 11:09:13 AM
Everytime I hear mention about the Markley lakester I think to myself it must have felt too safe to be interesting......so he put the periscope in. I hear a rumblin Stainless..We're a little further up in the car than you but not a lot. I am yet to confirm( I will at a DLRA meeting today) about the disparity between what the club will accept and the SCTA'a acceptance of some devices that are yet to be SFI certified.......
Anyone that's never been in a full lay down car won't know the sacrifices required to get there. The biggest issue , as Stainless said,
is getting your head forward far enough to see the land & thats where the collar-thing screws you.
I've been in the "Markley periscope tank", the driver position is not a full lay down, it's really comfortable & the periscope is bitchin. 30 seconds after you're in there, you don't even know you're looking through a mirror.
I liked the idea for the liner, but SCTA deemed it a no-no for a new car.
fastman614
I had a lengthy discussion with Joe at DJ Safety in regards to his HANR device.... and we use it in both of our cars.... the Vega is about a 20degree seat angle.... the lakester is 50 degrees..... DJ's system is adjustable for each and would adjust for an rven more laid back angle but it is my guess that there could be a limit beyond where it may not be able to properly support your had and neck.
What I understand from Joe is that there was a malfunction of something during the testing of the DJ system and they ran out of time for further testing. The testing labs with the crash testing equipment are ALWAYS booked for testing a long time in advance. The biggest reason for not getting SFI certification was due to their not being able to schedule further testing until some time in the future. I think that I have some of the test info somewhere but I had been asked to not share it or publish it as DJ was willing to do so in any case. I had a computer crash after receiving the information anyway so I don not have it on my laptop computer which is where it was... the papers were hard copy and I had scanned it.... so, the info is at home, but I won't be home for a few weeks. (I am at a gold mine project; setting up a ball mill.)
I was talking to DJ as well, sweating on them getting certification.
Their HANS device is gone from their website & replies to emails on the subject have dried up.
I'm ordering a Simpson unit & making my seat to suit, so ican keep going.
My seat isn't as laid down as yours Stainless as I'm looking over a 23" tyre that has 2.5" of clearance to the fender for compression suspension travel & tyre growth, my but is about 6-7" off the ground.
That gives me about 18" of height difference from my but to my eyeline.
A true lay down car with a periscope would be difficult I recon with the balance tubes in your ears & your eyes giving conflicting info due to your eyes seeing 90 degrees to where your body thinks they should, never been in one so only guessing.
