P/PP-1350-4
Started by runt13, March 04, 2012, 06:51:54 AM
runt13
WOW! SAFETY WIRING SUCKS! GLAD I BOUGHT 60 DRILL BITS.
RUNT
who would have guessed it would take so long to go so fast for such a short time?
2012 Wilmington mile
April meet,
p/pp-1350/4 record, 132.601mph
September meet,
p/pp-1350/4 record 139.915mph [bump]
p/pp-1650/4 record 142.364 mph
p/pp-2000/4 record 140.009 mph
p/pp-3000/4 record 144.511 mph
2013 Wilmington mile
July meet,
m/pg-1650/4 record 137.278
m/pg-2000/4 record 136.695
Sept meet,
p/pp-1350/4 record 141.1986 [bump]
2014  Wilmington mile
May meet
p/pp-1340/4 record 142.5855 [bump]
55chevr
Remember 6 to 8 twists per inch ...
runt13
that i didnt know, still on the drill the bolt ends part of it.
runt
April meet,
September meet,
July meet,
Sept meet,
May meet
runt13
ok, time to do the twisting of the wire.
really there is a spec on the number of twists?
i have drilled the front fork pinch bolts [4], the trans and oil drain plugs, hose clamped and wired oil filter, front brake caliper mounts [just cause i had them off], and my stealth rear under the inner fender belt guard. is there anything else i have to do to pass tech? [ as far as safety wire]
thanks RUNT
April meet,
September meet,
July meet,
Sept meet,
May meet
RansomT
Rear axle, pinned or wired.  Oil/Trans fill plugs.
I'm not aware of specs on the number of twist...I also could be wrong, too.
runt13
pinned?, i assembled the axels to spec, then drilled a 1/8 hole just outside the nut and put in a cotter pin in the hole....will that work?, fill plug is going to be fun...lol
RUNT
April meet,
September meet,
July meet,
Sept meet,
May meet
RacerX9623
Quote from: runt13 on April 22, 2012, 07:21:34 AM
there is a right way a wrong way and a British way to do everything.
This is a good safety wire explanation.
http://en.wikipedia.org/wiki/Safety_wire
cotter pins is good for the axle.
trying to go 200 KPH with a 250cc four stroke.
55chevr
Joe Timney
Fabricating Tips
Have you ever had a drill bit squeal like a pig instead of removing hardened metal or stainless steel? Those number drills getting dull after one hole? Next time, try a dab of Elmer's Glue! That's right, that white stuff that you used back in Kindergarten class. The lard in the glue will help lube the drill.  The glue will also keep the chips from flying all over the place.
Joe Timney
Retired President of ECTA
www.delawarechassisworks.com
relaxedphit
If there's lard in Elmer's glue, I'm surprised it's not fried and on some menu down here. Has the oil plug/filter wiring returned to the rule book? I've always done it because it just
makes sense.
runt13
thanks to all that gave me there 2 cents here, we went right threw tech with the bike. had a great weekend.
RUNT
April meet,
September meet,
July meet,
Sept meet,
May meet
So, Runt -- what'd you run?
runt13
saturday, rookie / rookie lic. pass 117.3MPH  got my 125 lic. sunday run 1, 117.1mph [my foot and the gear shifter were not getting along, grabbed a false nuetral between 4th and 5th]. 2nd run went 132.6mph [had a nice direct tail wind] 3rd run 130.1mph.
very happy with my weekend, i met my goals and then some. the only person more happy then me is the local bike shop that just got a huge deposit on my not so huge parts order. will be back in september. looking for 150mph, but will be happy with 132.7mph...LOL
RUNT
April meet,
September meet,
July meet,
Sept meet,
May meet
RansomT
Quote from: runt13 on May 02, 2012, 12:45:02 PM
RUNT
Don't forget ... keep eating that salad.   :-D
firemanjim
What are you intending to do to bike? I have a dyno shop out here and we do lots of Buell builds. 707 996-6103 Jim.
Got a chain on it yet? Do you have ECM-Spy and cable?
