Australian Streamliner Bike Build
Started by Jon, March 12, 2012, 09:38:19 PM
Jon
Quote from: grumm441 on July 29, 2013, 08:17:56 PM
Quote from: Jon on July 29, 2013, 05:08:44 AM
Quote from: grumm441 on July 29, 2013, 02:19:44 AM
Just don't put the gearshift too far away
You taking it for a run Grumm? Cool.
We're about the same height (I think) main shift is on the left thumb, underdrive to direct will probably be on the right.
Dave would have a better chance
Only one person going to have the joys of sliding down the salt wondering what happened in this ;)
Underhouse Engineering
DavieB
Quote from: Jon on July 30, 2013, 03:22:40 AM
:evil:
Jon
Getting ready to cut it in 1/2.
Squaring it up on the bench with cheapie laser crosshairs.
Going to tack a foot to the back of the main rollcage hoop and screw it to the bench.
I'll tack a light RHS frame to about the tubes in the engine bay about 100m behind where I'm going to cut it with a foot down to the bench to keep the height right.
Then cut it and spread it 500mm, probably totally replace the bottom rails and sleeve and extend the top rails.
The bottom rails will still be straight, the top rails will have a horizontal bend in them at the join, this will right next to one of the top engine mounts so that the engine becomes structural and the main rails are all effectively straight still.
Cheers
jon
Jon
Picked up the Waterjet cut plates for the B&J underdrive unit's outboard bearing plates and mounting plates today.
Just need finishing machining for outboard bearings, counter boring for caphead bolts any tapping other holes.
jon
Quoting Jon:
That's a long bike.
Elmo Rodge
Quote from: Freud on August 16, 2013, 07:56:38 PM
Quoting Jon:
That's a long bike.
Ain't it? By the way Jon. Those cheepie laser crosshairs is the way I built my car. After shooting optics for jig building I just kept that kind of thinking building my car. It saves investing in a perfectly flat floor. You can put the "floor" anywhere you want in space.  :wink: Wayno
grumm441
Quoting Jon:
That's a long bike.
Must have a big Garage
Dr Goggles
Quote from: grumm441 on August 17, 2013, 01:31:29 AM
Quoting Jon:
That's a long bike.
I feel obliged to get involved here.
Talk about buckling, first it was six inches, then eighteen...now in an effort to conceal your weakness you've gone metric.......100m, that's putting 10llb of Subaru in a 1000lb bag, you've changed man, you've changed. :-( :-( :-( :-(
Jon
Must get a longer earth lead for my welder.... :0
At that rate my bracing will on the front fence a few houses over, you've seen a flaw in my cunning plan.
Might have to put a bit more thought into it ....
Cheers
jon
Jon
#864
Called in and saw Ross today, as usual our conversation went all over the place talking about his liner and other toys.
In among conversation was chute releases, a while ago I bought a couple of the old frame mount tenspeed pushy change levers for thumb chute releases.
I didn't finish cleaning up like I said I was going to Ross. :roll: :roll:
Made a couple of mounts for the chute release levers that double as Master Cylinder clamps:
Horizontal back view:
Top/back view:
Venhill throttle that was destined for a cafe project, ZX-14 radial master cylinders (nice and narrow on the bars), Fleabay shorty levers and Underhouse chute release, dummied up on a random clipon.
Clutch side looks same.
Cheers
jon
Jon & DrG,  my hat is off to you two--- on your "packaging".  I have studied and restudied both your builds for inspiration  :cheers:
I quit worrying about suspension with tires when I figured out what the reaction distance would be with GM's electrionic-magnetic shocks at 300.
Jon
Thanks Sparky, if I'm able to give back a little help for the heaps that I've got from this site it will be good.
Seems to be plenty if successful cars without suspension but less so with bikes, wonder if it's to do with weight per wheel and bikes not having enough weight per wheel to have them flex over minor surface variations?
Same views as yesterday with switches, switches are set back on the bar to make them harder to bump and easier to work, switching horizontally for both the same reasons.
Will knock some corners off later.
All double pole switches using both contacts for a bit better reliability.
Left Upper: Single throw, Underdrive, away from hand for low, towards for direct.
Left Lower: Double throw Spring return, Main trans, away for downshift, towards for upshift.
Right Upper: Single throw, ECU/Fuel pump, away from hand for off, towards for on.
Right Lower: Double throw Spring return, Landing Gear, away for down, towards for up.
Probably just seems random but operating earthmoving equipment allways has towards for up, on or upshift and my head is used to it.
Cheers
jon
RidgeRunner
Quote from: Jon on September 02, 2013, 12:56:04 AM
Cheers
jon
     In my opinion that is very good reasoning.  I've always felt the sub conscious mind can save precious seconds, or fractions of, when needed as well as help keep the working environment user friendly.
Jon
A couple hours again today.
Most comfortable/best range of movement seems to be about 45 degrees downslope on the bars.
Made up a centre section for bars, same views:
Clamps the bars like normal clip-on bars, helicoiled M6 pinch bolts, nylon pivot bush, will put a grease nipple in later when I have it fitted up.
Cheers
jon
Koncretekid
Quote from: Jon on September 03, 2013, 02:42:07 AM
Cheers
jon
Jon,
I have a few comments.  M6 pinch bolts probably OK since handles are straight - - I found that I had to pin my bars to keep them from rotating.  45 degrees may not be that comfortable depending on your riding position.  My bars are almost parallel but further arpart than yours. Will you have direct steering or use some leverage, i.e. 1 to 2 to get more turning force if needed?  Some guys are comfortable with bars that close together, but not me!  Just food for thought.
