The first Ohio Mile, I'm ready
Started by garrell patterson, April 08, 2012, 07:20:07 AM
jreken
Moxnix
jreken, I'm the volunteer audio guy for Seldom Seen & Co., webcasting the events for this forum live from the venue whenever possible to whoever can tune in on their computer.  Other than that, I type messages not understood by anyone.
LSR Mike
Mike M.
BNI/ECTA
dr j
Moxnix,
Usually CB Ch 1.
Music- none of the above, at least come up to the sixties...though some can't remember them and some others weren't born yet.
We'd love to have the live audio while we wait in line.
Jarl- Moto Madcap
Sharpsburg MD
BUB2012- Morini 350- 4 Mod Pushrod records, Parilla 175- M-VG rec
250cc 4stroke Nitrous Motorcycle- 131.8mph
250/4 Naked Motorcycle-115.6mph
APS/F-125/2 115.2mph
P/PV-175/4 Moto Parilla-59.7mph
29 Retired Maxton Class Records on 3 bikes and 4 engines
fredvance
I lived through the sixties, barely, cant remember much. :roll:
ronnieroadster
  Our Lakester is pretty much ready to go. Still running the old motor from last season which went threw a huge tuning curve burned pistons damaged valves and related damage. The old flathead Ford V-8 block is now freshend up its ready for some more abuse. Were looking forward to running on a smooth surface and hopefully the speeds will be similar to the October Maxton runs.
Captthundarr
Took Amy's Camaro to the drag strip this afternoon for a final shake down to check out the c-clip elems and the new manual valve body in the tran. Dang if the thing is still overheating. Flipped the fan to pull thru, water pump, thermostat and everything working.will Idle all day with no problems, only over heats under load. too lean?? timing?? Oh well at least everthing else is good. the car pulls hard and a 1/4 mile aint long enough to get it into 3rd gear. We'll get it figured out.
Jon
Is the bottom radiator hose holding it's shape under revs?
cheers
jon
Underhouse Engineering
geezer1
We're ready to go. Chassis dyno tomorrow. Martin US 131 drag strip on Saturday. Need to stop by Meijer's Thrifty Acres and get some E85. Really looking forward to seeing everyone in Ohio. Come by the Wilmington Inn or by our pit.
Geo Turner
Geezer Racing
Geezer Racing - (Turner/Herr/Mclellan/Acton/Pranger/Acton/Acton /McDonald/Hascall/Patul)
Trever is in at over 210!!!!!(17 yrs. old) Kyle is in at over 212!!!!! (16 yrs' old)
2 Wins in the Hot Rod Top Speed Challenge in Super Street 2014-2015
5 Different Geezer Drivers set records at Maxton, Loring, and Ohio
We also had the honor to have the fastest Innkeeper in Wilmington Ohio in the Geezer Express
Thank you ECTA and our great LSR Friends! Press On Regardless!!
saltwheels262
talked to jim at kelsos welding in wilmington.
he does custom fab work;
tig and mig on aluminum and steel.
open from dawn till dark.
open saturdays.
5 minutes from the airport.
he can be reached at 937-725-7711.
franey
ohio -    - 185.076 w/#684
lta 8/14  - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
                            - franey  8/2007
garrell patterson
Mr. Turner I plan on stopping by your pits for a visit if the invite is still on.
Garrell
garrell patterson
wheelrdealer
Everyone at Wilmington, go fast and be safe. Wish I was there.
geezer1
Quote from: garrell patterson on April 19, 2012, 09:56:42 PM
Garrell
Looking forward to it...!
It really makes no difference.
