July Videos - Post Here
Started by Cajun Kid, July 16, 2012, 05:23:39 PM
Roland6250
Powered Streetluge motor - 1200cc but the motor has been built high speeds.  Engine work was done by me but the machine shop work was done by Andy Simons of Simon's Competition out of Langhorne PA. www.simonscompetition.com
  • Heads where pocket ported with bee hive springs, nitrate coated light weight valves and light weight caps
  • Cylinders where bored 5 over standard and wisco stock cast pistons installed
  • Trans was rebuilt and has back cut gears
  • Non rev limiting Dyna ignition
  • Jims lifters, Jims pushrods and stock cams
  • S&S Super B carb with S&S intake
Dyno recorded 85 hp to the rear wheel and a top speed of 193mph.
N.F.S.
Quote from: Roland6250 on July 19, 2012, 02:15:22 PM
Thanks just wondering because speed you where getting but than again it's not in a motorcycle chassis either.
saltwheels262
169+ is a pretty good speed for a 74 cubic inch engine.
what is the overall gearing on your ride ?
bf
ohio -    - 185.076 w/#684
lta 8/14  - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
                            - franey  8/2007
55chevr
My mistake ... it was a B carb, not an E ... Joe
