Source for good quality CV joints and rebuild kits?
Started by SteveM, March 27, 2013, 05:15:45 AM
38flattie
Stan, you're absolutely correct-but when you need what you need, sometimes 'prodding' is the easiest solution! :wink:
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
Ken Yooper
As I remember the two suppliers for those CV shafts were Citroen and GKN.  Perhaps someone still has a catalog for these folks.
If it's worth doing, it's worth doing right.  If it's not worth doing right then it's probably not worth doing at all.  (Andy Granatelli in Gasoline Alley 1964)
SteveM
Quote from: Ken Yooper on March 28, 2013, 02:46:25 PM
Based on the records I've seen, you are correct about Citroen and GKN.  I've ordered a set of Ebay reman units for a '79 Horizon, mainly to get my hands on what should be the correct length shafts.
maguromic
On our RMR we will be using Lobro CV joints, same style as  the 935.  Tony
Tman
Quote from: maguromic on March 28, 2013, 08:38:32 PM
Pegasus is one that has Lobros. FWIW
