"reactive" - sorry to bring this up again.
Started by Briz, April 07, 2013, 01:02:06 PM
V4F STR 60
Like I said above, I was simply borrowing the word 'reactive'.  I agree that it's not the best choice of words for this application.  I too prefer 'feedback'.
Thanks for proving my point that there is no effective difference between a distributor and crank trigger(s).  The both simply tell the coil when to fire in relation to crank rotation.  As you mention, a distributor actually has more provisions for 'feedback' in that it has provisions for both mechanical and vacuum advance.  A MSD 6214, while 'digital' has no provisions for 'feedback'.  It is simply a very basic waste-fire Sprint car ignition.
Montana Dodge Boys Fast Four Special
1928 Dodge Brothers Vintage Flathead Four Cylinder Roadster & Lakester
Landspeed Records
Bonneville
2009 V4F/STR 115.681
2009 V4F/GR 116.439
2009 V4F/FR 117.597
2010 V4F/BSTR 127.352
2012 V4F/BFMR 130.843
2013 V4F/BGMR 142.956
2013 V4F/BFMR 143.254
2013 V4F/BGR 138.395
2013 V4F/BFR 138.984
El Mirage
2016 V4F/BGMR 140.961
www.facebook.com/MontanaDodgeBoys
www.fastfourspecial.com
Briz
If a non-feedback simple electronic ignition is allowable, I imagine that a problem then arises for tech inspectors in determining how many functions an anonymous looking black-box is providing.
Maybe a hall-effect pickup running thru something obviously recognizable, like a GM HEI module?
Vinsky
The Hall effect design can be called electronic, but it's trigger, or switch is simply a magnet.
http://www.bristolwatch.com/hall_effect/index.htm
Guess you could call it a virtual set of points.
I  have a ARD CDI magneto and a Dynatek 'electronic' ignition. Will either one of these pass inspection?
NathanStewart
I talked to the bike tech chair(s) at the last board meeting and they said non-reactive means non-reactive as in it doesn't react to anything.  Basically fixed timing.  I'd think the plan to use an HEI module would be acceptable as HEI's still relied on a mechanical advance to control timing so the modules themselves can't directly control ignition timing, only the switching of the coil on and off.
In either instance, your best bet is to contact the bike tech chair(s) before showing up to an event.
El Mirage 200 MPH Club Member
grumm441
I think you have to look at not just the word reactive but also the context of the sentence in the rule book
" newer technologies such as EFI, or electronic reactive ignitions are not in keeping with the spirit of vintage rules and are not allowed."
so it says "electronic reactive ignitions"
When I asked Matt Shuss he said
QuoteTom can correct me if I'm wrong, but it is to disallow ignitions which adjust to boost, A/F readings, knock sensors, etc.
Which was what I thought it meant
