Speed Reader - Amy's '91 Camaro C/GALT
Started by Captthundarr, May 25, 2013, 07:12:16 AM
gkabbt
Quote from: Captthundarr on June 07, 2013, 02:21:04 PM
Oh well I guess I'll have to come up with a diff combo as that was what I was thinking of running as I have some of the bits and pieces on the shelf already :-o Great minds think alike eh Gregg :cheers:
Frank, go for this combo with your Spitfire in MS.  :cheers:    My GT6 will be for the street only.
Yeah about the great minds thing and that is why it was so funny to me.  :-D
Gregg
Captthundarr
4-barrel Mike
Quote from: gkabbt on June 07, 2013, 02:16:39 PM
Mike....Yes and Yes and with a Thunderbird 7.5 IRS diff. I'm on Turboford as GT6GKA although I don't post much.
Gregg
Yep!   8-)
redhotracing
Quote from: Captthundarr on June 07, 2013, 06:15:17 AM
Yep Luke there is a sweet spot on the TL's to "bang da gears". I might have to start scrounging parts. Another improvement for next year will be swapping out the 3.08 rear gears for 2.73.
Frank.
2.73's are great for top end, but make sure you
have the HP to push it. We put the 2.50's in the
Camaro with the expectation of Bonneville and
lost MPH in the mile... Would have hit 200+ at
Maxton with a 2.73 or 3.00, only got 196.xxx :(
Luke- Winston Salem, NC
Loring 2 Club- 201.252 (2010)
Ohio 2 Club- 203.712 (2013)
#79
Gear for the eng speed you want at the START of the timing traps
Captthundarr
Captthundarr
Sorry for the delay in posting, I'm having some trouble that Sir Jon of Slim is working to resolve. Please stand by.
Captthundarr
2012 we had overheating problems. 1. water pump wired backwards at the factory, no shite. no really. and the stock radiatorwas not up to task. We replaced it with a double pass 2 core. man that thing holds a lot.
Captthundarr
Made some brackets as none of the stock stuff would work.
Captthundarr
The stock steering column was in need of replacement. The tilt mechanism started to fall apart. Real race cars aint got no tilt streeing. So picked up a new column from Trent. pretty nice for the price. Being one that will repurpose parts as oposed to buying stuff the old column was about to become a fire wall mount for the new column.
Captthundarr
The old column firewall mount was a conveniant tidbit to use to monut the new column. After wacking the tube and a little drimel work on the lower bushing, it held the new columnat the needed angle and there were no more problems trying to seal the hole.
Captthundarr
#86
More streering column. Made the upper mount and viola a new solid steering column to keep Amy pointed in the right direction. total 3 hours fab time including smoke breaks.
Captthundarr
In addition to the new column I took out the power steering box after convincing Amy that she could steer it just fine with a manual box. A clean and tight fleabay purchase did trick. aslo gained a few more ponies as well.
Tman
Column looks nice, I like the mount parts. Always a pleasure to deal with you guys!
Captthundarr
Thanks Trent, the parts are spot on. Heres a few pic's of some other things we did "just because".
Whipped up a new gas pedal as the old stock one was getting loose. finally added some inner door panel to clean it up and reduce the risk of Amy getting hung up on something while getting out of the car.
