Event gas at Bonneville
Started by lsrjunkie, September 24, 2013, 02:15:03 PM
jacksoni
Jack Iliff
G/BGS-250.235 1987
G/GC- 193.550 2021
G/GMS-182.144 2019
G/GCC- 194.580 2025
We do the same thing as mentioned earlier.  ERC is hard to get here so the tuning is done with Sunoco Standard and 110K is used at the event, if needed.  I cannot tell any difference between the fuels so this works great.  Both are good gasolines.
#32
Quote from: jacksoni on September 26, 2013, 06:09:54 AM
Personally, I have never seen a fuel check though I suppose they get done time to time.
Jack, that's an interesting point.
I remember going to El Mirage in the '90s, and I believe it was Chuck Kalbach's car being tested for fuel with an electronic insert that was put into the tank on a long stick.  I asked him about it, and he explained that alcohol and nitro methane have different resistances, so that is how they were able to distinguish gasoline from fuel.
Maybe it's no longer possible to do that - gasoline formulations have changed dramatically in the last 20 years - but I can't ever say in the times I've been to Bonneville I ever saw gasoline tested in this manner.
Maybe I just missed it.
I know after my rookie pass, after I pumped out my tank, they beat on the bottom of it, it made a "clank", and they sealed off my tank after I filled up.
If they don't check after a record run, well, heck - A quart of nitro methane could easily be put in the tank through a vent.
jacksoni
They of course do check that the tank is properly sealed and yes, that you arrive at the fuel truck empty. That is not what I have meant but that I have not seen an actual sample taken for testing. Others have, of course, as has been mentioned. The rule book does have specific diaelectric and other features that are supposed to match. As I alluded previously and Chris just stated, non legal components could be added through a vent etc if you want to but as has been stated, if you want to run a lie (not just running afoul of rule interpretation or misunderstanding) so be it. Again, Dan told me anything gasoline wise on the fuel truck was "legal" event gas.  Having in the past thought that only the 110k was the "event gas" when I was running a blown gas liner, I would have liked to use one of the higher octane blends.
Jack Iliff
G/BGS-250.235 1987
G/GC- 193.550 2021
G/GMS-182.144 2019
G/GCC- 194.580 2025
"Test on whatever you want.  Show up and tell Rick what you've been using.  And tell him what you're running. CR and so-on.
He'll give you what you need.  No need to worry about that.  Lots of other things to worry about.  He'll know what's best for you."
What I was trying to convey was that Rick will help you match up his product to as close as the product you've been using.  And a lot of folks think his advise is solid if you don't have a clue on what to use -- as I did.
lsrjunkie
Thanks Stan. That was my big concern. I didn't want to build a motor that we tuned on gas available here and then not be able to get the same octane out on the salt. I won't need 120 octane, but I wanted to make sure that if we tuned on 110, I could get it on the salt.
sabat
One consideration is that if your engine is tuned for another gasoline, Rick will advise you to choose the safest fuel from what he has available. For example, your engine might perform better on MUL/B, but if Rick isn't sure if your engine will tolerate it, he might steer you to 110K to be safe. Thus tuning on another fuel and leaving it up to Rick to decide is fine, but you might leave horsepower on the table. -Dean
