Anyone looking for a rearend with a taller ratio????
Started by Sumner, January 07, 2014, 03:54:15 PM
That's a bunch.  But might deliver more than an expensive quick change using more gears to get the same ratio.
37str
Dynoroom
I think the demon has run a quick change, a custom weisman, but I don't know about a 9".
tauruck
I was advised to stop looking for the obscure Ford 9" ratios. Good advice but I'm bull headed.
I've been looking at a Winters Xtremeliner and it's more affordable that those ratios from MF.
I was at the classic car club yesterday and a friend Hamish said there was a gear cutting business he used that did hypoid gears for him.
Even though we're in South Africa we do have some very good engineering facilities and guys that know their stuff.
I'm going to see the gear cutter on Monday. Hamish's day job is all things Rolls Royce and I've seen jet engines at his place so the guy does have high standards.
If he says the guy cuts good gears there might be an affordable solution there and one offs are not a problem. He said the guy ran the set he had made on a jig to bed the gears in.
Not sure of the exact term.
I'll let you know if Hamish was on the money or he had a few too many ales. :-D
7800ebs
get a 12 bolt gm 2.29 gear
call strange engineering..
get their drop out 9" ford center section that takes a 12 bolt gear..
there you go, a high pinion 12 bolt, with a high ratio gear in a 9" ford
bob
Quote from: 7800ebs on January 18, 2014, 05:25:34 PM
bob
That is what Tom has been telling us also.  It is on the table.  The hard part so far has been trying to locate the 12 bolt 2.29 gear itself?
Bob Drury
#36
  I may have misunderstood Mike about the Speed Demon.  He may have told me that The Speed Demon guys were running one in the Blowfish, or maybe they modified the quick change to use the gears........................
 My mind sometimes goes into overdrive with only a underdrive capacity.........................  one run, out.
Bob Drury
7800ebs
maybe something like this would work.. fits 9" fords
Bob Drury
  That is a Jones quickchange and I think Russ Meeks runs one.  The Tea Baron bought one from a friend of mine here in Vancouver and then he listed it for sale on this site about two years ago.  I don't know if he sold it or not................. Bob
Bob Drury
Thanks for the pictures.  Tom told me about those and before that I've spent many a night laying in bed designing one I could make using quick change gears.  One problem I see is that to get the rotation right going into the rear you need to have two sets of gears vs. one set in a conventional quickchange and that means more HP loses and also the gears are a lot harder to change, but at least you could change them vs. just one gear in the rearend.
The guys that run the long nose yellow stude out of Wash. made an inline box that I think had a driveshaft on both sides that did about the same.  It was a nice one-off piece of engineering that with the driveshafts would work with any trans/rearend combo if you had the room,
desotoman
At one time I thought about making a gear changing unit like the Jones's but using a belt instead and having the drive shaft off to the side. I think it would be good for 1000 HP. on the salt.
PS. Thanks Bob D. for the phone number for the 2.30 gears. I think the SD streamliner ran a 9 inch ford unit once, after they blew everything else they had up. At least that is what I remember I think Ray the Rat posted that information one time. I also think it only lasted one run.
John Burk
Has anybody found 10 bolt 2.29's and 2.14's to be not strong enough . A Casale V-drive would work the same as the Jones QC . It takes a bunch of grinding and welding up windows in a Strange dropout to get 2 series 12 bolt gears to fit .
Quote from: John Burk on January 18, 2014, 08:08:56 PM
Has anybody found 10 bolt 2.29's and 2.14's to be not strong enough . ...
I'm assuming you mean the 7.5 rear.  That is what I'm now using and has worked for Sparky with 900+ HP in the past.  He will also be the tester for much higher HP numbers now that he has 2 turbos.
I'm leery of that route with Hooley's 5000+ lb. Stude and hopefully some 1400+ HP numbers at some point.  I've found 26 spline full spools for the 7.5 but that is it so far as an over the counter item (probably some 28's out there).  Sparky runs a Torsen center and that is what I'm going to run and it is 28 splines.  There again 28 splines in the 1200+ HP heavy car might not work.  Thus the reason I still haven't given up finding a reasonable, read not super expensive solution using the 8.75 with the 2.28 gears that aren't that hard to find for Hooley's car,
Jack Gifford
#43
Quote from: Dynoroom on January 18, 2014, 04:04:26 PM... I think the demon has run a quick change, a custom weisman, but I don't know about a 9"...
If I remember right, the Weisman is a unique configuration, not using Ford 9" nor any other ring and pinion design. It eliminates the inefficiency of hypoid gears by driving first through a bevel gearset (non-offset), then through spur gears (including a quickchange set) to the differential case (or maybe directly to the axles, can't remember).
M/T Pontiac hemi guru
Jack Gifford
The problem with the Jones and other "front" quickchange boxes is that you're still spinning the differential's pinion fast. This may or may not be a problem. This anecdote about Mickey Thompson comes to mind: when planning his assault on Cobb's record (408?), the first pieces he "whittled out" were the 1:2 ratio spur gear sets to be employed at each wheel- to avoid pinion shafts needing to spin 13,000 RPM!
