Belly Pan
Started by Huffy047, March 03, 2014, 04:27:47 AM
Tman
Quote from: 4-barrel Mike on March 04, 2014, 06:42:48 AM
Quote from: Bob Drury on March 03, 2014, 11:12:32 PM
  It's about $175. every two passes if I do it myself (dang methanol and Nitro).
                                                :-P :-o :-P
Ol' One Run:
Every other year?   :evil:
That is a stinging blow!
Quote from: Crackerman on March 03, 2014, 06:54:33 AM
At that point an engine diaper to contain the blast, and soak up the oil to keep it off headers would be a necessity. I would think the two in conjunction would work together better han just a belly pan with drain holes...
I suggested engine diapers a few years ago but they didn't show any interest, sure would help keep debris and oil off the courses.
Quote from: Glen on March 04, 2014, 07:50:30 AM
I wonder if that is because we are more concerned with the driver than the course in this situation.  If the oil is trapped in the diaper it is still in the car where it could burn.  In this case I think I'd want it outside the car in case there was a fire,
Bob Drury
  Mike, every third year....................    :-P :-P
Bob Drury
modelAsteve
Maybe we could get DEPENDS as a major sponsor- even on the front of the event T-shirts!
Huffy047
Thanks to all, from this I see one person commented to as many as needed 1/2" holes? I'll do that and hope I can get through tech.
Bob Drury
  Huffy, first contact the tech chairman for what ever category you run.
  If in fact you show up and a problem is noted, I am pretty sure that duct tape would suffice as a quick fix, and don't buy the cheap sh*t, buy Nassua 357 at Home Depot.
  You may want to limit the number of holes you drill so as to keep as much salt OUT as possible.  You can always add more.
Bob Drury
nivtop
Quote from: manta22 on March 03, 2014, 08:33:15 AM
Stainless;
Didn't that rule come about due to Bob Herda's streamliner fire?
No the rule was there before Herdas fire. At a drivers meeting the day after this was made clear.
Huffy047
Thanks to all, as Bob says, if the officials are not happy, "Just drill more", sometimes the simplest souloutions are the hardest to figure out.
redhotracing
Run a line or two from the drain holes to a catch can?
Luke- Winston Salem, NC
Loring 2 Club- 201.252 (2010)
Ohio 2 Club- 203.712 (2013)
Quote from: redhotracing on March 06, 2014, 01:26:18 PM
Only if you don't want to pass tech...  :cheers:
Kansas Bad Man
One year I did a lot of body work on the liner. Going thru tech the guy ask, do you have drain holes, answer yes sir , 5 of them, he ran his hand over the bottom to check , I don't feel any thing, I took a feel, nothing, I had marked the holes and Stainless had forgot to drill the holes! That's my story and I'm sticking to it!!! :-D
Quote from: Kansas Bad Man on March 07, 2014, 12:29:07 PM
:-o Hey, I resemble that remark
Bob Drury
  Stainless, there ain't nothing Holy about you as far as I can tell..................................... :evil: :evil: :roll:
Bob Drury
