Nice wind tunnel shot
Started by Bob Drury, March 14, 2014, 10:08:25 AM
Bob Drury
  If you go to http://www.dragracingonline/agent1320 there is a great shot of Alan Johnson's new Mopar Pro Stocker in a wind tunnel that shows amongst other things why you don't want a low scoop on the hood of a race car.  The difference in low and high pressure air is quite evident and also shows why funny cars run such a high wickerbill to gain traction on asphalt.               Bob
Bob Drury
sabat
How come the guys in these tunnels never hold the smoke generator close to the floor?.
I want to see the air flow around the splitter. :-D
It's time for SSS to ask another one that many know, I'll betcha.  What's a "wickerbill"?
Usually $5 to $10, depending on height.
interested bystander
Wicker bill is a Gurney lip. Across the Pond is is a definition of part of one's private parts (male)!
Thanks to the aforementioned Stan Beck who donates his issues of Automobile magazine to the home , this month's  has the intro of the Dodge Dart featured.
Using a well worn phase, if that thing in the tunnel is a Dart, my Uncle's my Aunt!
5 mph in pit area (clothed)
Male private parts are one thing that I think I know -- but a Gurney Lip?  You guys aren't helping me very much.  Thanks for trying, though. . . :?
Dynoroom
We would slide in different Gurney lips to balance speed with handling just before qualifying.
Hope that helps.......      :-P
I`ll try Jon. On most serious race car rear wings there`s an L shaped lip across the trailing edge. It can usually be changed to vary the height and thus the airflow. This has a very noticible effect on the efficiency of the wing. The L shaped piece is a Gurney lip on this side of the pond or a wickerbill over `there`.
hotrod
It got its name due to Dan Gurney's use of the technique to quickly tune the down force on a rear wing.
It is a small vertical lip at the trailing edge of a wing (hence the name lip) which significantly increased down force for a very small increase in drag.
It's primary advantage is that they can be engineered to be easily changed during a pit stop to increase down force or reduce it by simply sliding out one lip and inserting one of a different size.
It was a spur of the moment invention that revolutionized racing.
http://www.insideracingtechnology.com/Resources/gurneyflap.gif
http://allamericanracers.com/the-gurney-flap/
WOODY@DDLLC
According to conventional wing wisdom it really should not work!  :?
But this is what happens [sometimes] when you deal with hot rodders!  :-o  :-D :cheers:
4-barrel Mike
"The purpose of science is to explain how hot rodders do what they do." – Scott Guthrie (IIRC)
gkabbt
Quote from: interested bystander on March 15, 2014, 05:43:48 PM
Just saw this thread!
IO.....ROTFLMFAO!  :-D   :cheers:   :-D   :cheers:   :-D
Looks like NHRA is going/has gone the NASCRAP route!
Gregg
Here's a link to a Bangshift.com page that holds a video of a car that ran for the first time at SpeedWeek '13.  Here it's tested in the A2 wind tunnel.  If you were there you probably will recognise it.  I didn't bother to create a new topic for it - that's why it's on this one.
http://bangshift.com/bangshift1320/watch-incredible-stupidbaker-land-speed-car-get-wind-tunnel-tested-a2-wind-tunnel/
I corrected my error - which Mr. Kitchen was kind enough to point out to me ( not to all of you).  Thanks. :-)
