My Salt Dream : VW Karmann Ghia
Started by wickedwagens, April 23, 2014, 10:35:14 PM
tauruck
Awesome report and congrats on the record. Not easy to come by.
You guys did great. So happy for you. That car is super clean. :cheers: :cheers: :cheers:
Congratulations on a great first outing. The car looks great.
It sounds to me like it's time to head home and spend a couple of days doing a really thorough clean-up and lube/rustproof and then get the turbo engine ready. I see more records in the future.  :cheers: :cheers: :cheers:
SteveM
The car looks fantastic (I love the blue color), and congratulations on putting it in the record book.  That Speed Week trophy will look great sitting on the mantel as well!
Thanks for taking the time to talk earlier this week. Nice car- great job!
gkabbt
Here are a couple of pics I got of your KG in inspection. As everyone has said, nice car!
Gregg
Sitting right next to Eddie Van Scoy's #128 Corvette.....
gkabbt
You're right Neil and there are several pics of his car in my picture post thread.
Gregg
wickedwagens
#67
After Speedweek I had a couple of things to fix.  One was that the car need a source for fresh air.  For some reason I thought that this was only for El Mirage.  I found these from Aircraft Spruce and they do a good job.
I also had to move the fuel line and seal up some ports under the hood.  I ran a tube through the car and ran a new fuel line inside of it.  I also found that I could use freeze plugs to seal up the fresh air ports under the hood where the fuel cell is.
I took the heads off of another engine I have and swapped them to raise the compression from 8.7:1 up to 10.2:1.  I also got a sponsor "Retro Racing" that provided 32mm venturies and 140 main jets for the carburetors.  I installed a set of 1.25:1 rocker arms with new valve springs and a new merged header.
With the car back together we loaded back up and headed to World of Speed.
Tech was a breeze this time and we made it through with no issues.  After waiting in line for a good 4 hours we got the first run in at 2:30pm.  110mph and off to impound for G/CGALT.  The next morning we backed it up with a 115mph run and we set the record at 113.131 mph.  I'm learning a lot on how the car handles and good driving techniques.  Another good event.
1968 Volkswagen Karmann Ghia
G/CFALT  106.643 MPH  8/2016    G/CGALT  113.131 MPH  9/2016
G/CBGALT  169.462  MPH  8/2021    G/CBFALT  146.715  MPH  8/2017
G/CBGC  158.242  MPH  9/2017   H/CBGC  94.334 MPH  8/2018
H/CPRO  93.383 MPH  8/2018   H/CBFALT  101.282 MPH 9/2018
H/CBGALT  120.591 MPH 9/2018
Top Speed 170.726 MPH
36hp VW 100 mph club 9/2019 102.319 MPH
wickedwagens
I want to switch from the normally aspirated classes that I raced in last year and go to the turbo class. I have a displacement limit of 122.9 cu in. For this year I chose a 1915 cc or 117 cu. in. for what I thought would be an easy straight forward build. It is starting to get interesting. Here is what I have so far.
New AS-41 case
DPR 69mm crank chevy/buick journal
I'm looking at 3/8" ARP bolt 5.6" H-beam rods
The cam is a R304 from Shag @ SL-1 racing .521 lift 304 duration
94mm AA True Forged pistons and cylinders
AC.net revmaster 049 L6T heads
RLR 4 barrel drawthrough carb
I'll get some pictures posted as I start to assemble.
SteveM
 :-D
....things are going to happen fast now.....
wickedwagens
Checked all bearing clearances and started to assemble.
Setting up deck height.
wickedwagens
Short block is done. Just waiting for the cylinders from the machine shop and the new turbo.
wickedwagens
I had Herbert Performance hone my cylinders to .006" piston to cylinder clearance and I set the ring gap to .023" top and .024" second.
long block done.
wickedwagens
It's in the car.  Still some fabrication to do, but it's getting close.  Little things now.
Buamotorsport
Looking good. Good luck on the Salt. I will be driving 7551 rear engined roadster so come say hi.
