Weight and Balance
Started by jbryant200, June 20, 2014, 09:50:26 AM
631
good points on the complexity of 3D shapes and flat side surfaces.  The on course airflow may not agree precisely with the paper area calculations for a particular vehicle and all of our cars are going to have some divergence from our simple calculated results.  The point of the exercise is to get a base line idea of the high speed stability of our cars.  Wind tunnel time will validate (or not) our stability assumptions but not all of us have access to these great devices.  Grease dots are a time honored land speed method of seeing where the air goes around a vehicle at speed, taped yarns and an on board camera are the information age replacement for grease dots,  suspension data acquisition is great info as well; stiff wire, zip ties and tape can provide simple data in place of sensors.  Weigh the car, figure out the area center of the side of the vehicle, do the cut out test then make some assumptions and next summer spend a few work up or test runs proving or disproving the stability assumptions. The 411 streamliner was designed by a young mechanical engineer using paper and pencil proving to me that good results are possible applying the basic principles of mass in motion traveling through the air.
killajoule
Eva Hakansson here.
Sumner - you are absolutely correct. There is a typo in the calculation that carried through and the equation is flipped (it is correct in the text and wrong in the equation). Sorry about that.
It's the result of late night typing. For some reason, making a living always gets in the way of racing and you end up working late nights...
The example calculation was a fictitious example we made up for the article. I have all the calculations for the KillaJoule, but we decided to not use that as an example because the three wheels and the asymmetric body makes it a bit more complicated.
I have sent a revised version to Rex Svoboda. I hope it the current version will be replaced soon.
// Eva
Quote from: Sumner on June 21, 2014, 10:08:31 AM
Quote from: 631 on June 20, 2014, 07:12:25 PM
Note the article on CP CG in the tech & FAQ section.
Thanks, that is a good article ....
http://www.landracing.com/docs/CG-CP_Hakansson-Dube_4-2014.pdf
and is a little more technically orientated finding the CG vs. placing two jacks under the car on each side to find where it balances and where the CG should be above that point.  If I had weight scales available I'd try that and compare it to the 'jack method'.
SSS if you can you might want to fix a small mistake though. There was a mistake in the part on figuring the CG.  It should be....
Rear Left     117.25 ...... 1130 ....... 132492.5  (not 112492.5)
Total ......................... 4674 ....... 292446.0
292446.0 [inch-lbs.]/4674 [lbs.] = 62.56 [inches]
I also turned the numerator and denominator around in the line above as that is the way I'm use to seeing them, but maybe I'm wrong,
Gasoline?! That is _so_ last century!
KillaJoule - FIM/AMA/LTA record holder, the world's fastest electric motorcycle and the world's fastest sidecar motorcycle. Official record 240.726 mph (AMA, Aug 2014, pending ratification), recorded top speed so far 270.224 mph, but we are just getting started!
www.killacycleracing.com
www.facebook.com/killacycle
www.youtube.com/killacycle
Quote from: killajoule on June 21, 2014, 09:51:37 PM
Eva Hakansson here. ...The example calculation was a fictitious example we made up for the article. I have all the calculations for the KillaJoule, but we decided to not use that as an example because the three wheels and the asymmetric body makes it a bit more complicated.....
Thanks for taking the time to do the article.  I think it explained everything very well and hope others take the time to read it,
killajoule
Thanks, Sum.
The article is just a "rule of thumb" type guide, but we find the method very useful.
Most of us Bonneville racers will never get anywhere near a windtunnel. If this simple method tells you that your CG is behind your CP, then you will know why your vehicle was handling badly. There is no point spending money on windtunnel time until you have made some attempt to fix the CG-CP issue.
// Eva
Quote from: Sumner on June 21, 2014, 10:00:13 PM
#34
"There is no point spending money on windtunnel time until you have made some attempt to fix the CG-CP issue. "
Maybe that should depend on what speeds one is trying to run---a lot of the faster cars have had frt. end lift issues---some very successful ones ---have had body changes in route to that success
some have just wrecked without changes---if the ride just gets better and better---it may not be a smoother track  :-o
One problem with having a lot of weight back past the rear axle or near it is how the vehicle reacts to bumps or dips on the track.  Weight behind the axle can actually lift the front end of the vehicle if it hits a bump.  My experience with this is with pick-up trucks overloaded with fire wood.  It is not racing, although the principles are the same.
RidgeRunner
     A buddy who had a general repair garage put together his own roll back truck back in the early '70s using a truck with a marginal WB.  Having borrowing it for a move once, I can testify that the results were the same on a larger scale, front end could get scary light real fast.  He didn't use it any more that he had to until he could get it on a truck with a longer WB.
On my car I start out with most of my cooling water 20" behind the rear axle---during the run I actually move about  80# from behind the rear axle to 108" in front which really helps on trying to get CG more in front of the CP.
maj
My only experiance with this sort of thing is 10 yrs in dirttrack sedans, and how relevant it is to salt is anyones guess
But it left an permanant impression of weight in front of rear axle = good
and weight behind axle =bad
So much easier to steer in a slide if the back is not acting like a pendulum, leverage over contact point sort of feel
I still apply this to the bike rear fairing i had previously built and in the process of doing again, i feel it needs to be long for better aero shape minimising separation , so i put the tire right back out there too and this gives me more room to put weight in front of the tire, and transfers more of the total to the front tire
Richard 2
I found this 101 site on CP and CG of rocket stability and thought I would share it.
Shows a simple way to find CP and why it is necessary to find it in relationship to CG.
4 cylinder Esslinger
Could of had a V8
Graham in Aus
#40
Sparky, that is smart thinking.
Greg, I read somewhere that when one increases the wheelbase the front wheel trail needs to be increased, too.  The trail vs wheelbase on the Triumph was 8% before and after it was lengthened.  It was a lot of work to increase the trail and it was harder than stretching the wheelbase.  Was what I did really needed?
jbryant200
Quote from: toclub on June 20, 2014, 01:31:26 PM
How do you calculate the center of pressure?
The center of pressure is complex. There are considerations that include strakes, whether or not you have open wheels (if you do, BOTH sides of the wheels are included in the calculation), wings, spoilers, and other items not included in the rough estimate using a profile.  The profile approach, as already discussed in this forum, is a surprisingly good estimate.  There are a number of us in the LSR community that are willing to provide an unofficial calculation for those interested. We are also willing to provide additional feedback depending on your handling experiences, speed goals, or plans for body changes.
I have found that the LSR community is truly a supportive network. We want to be a part of this, especially since we have seen such a large increase in worldwide interest. There are many new projects in the pipeline and we hope that forums like this serve to help these new teams learn the safest ways to approach design.  Help get the word out!
"I have found that the LSR community is truly a supportive network."
This is so true  you will find there are LOTS of folks that will keep you from making "numbing" rookie mistakes!!  LSR  is
" SO non COOKIE CUTTER"  as some one has as on their sig.
"If the objective is to skin a cat---SO LITTLE TIME SO MANY CATS"
We are all dealing with exactly the same thing:
  " TOTAL DRAG VS TRACTIVE EFFORT"  :cheers:
Richard 2
Quote from: Richard 2 on June 23, 2014, 07:41:06 PM
http://www.rockets4schools.org/images/Basic.Rocket.Stability.pdf
Forgot the address, up to late I guess.
Richard 2
Could of had a V8
