Modified roadster construction
Started by Dynoroom, August 01, 2006, 04:55:58 PM
Mike,
Those are beautiful headers!!! I agree about header gaskets on turbo motors, when I was at Interscope we never ran gaskets on either our NA or turbo motors, they always blew out. A little red RTV and bolt them on, and we ran some pretty good boost on the V6 Chevys.
Tman
Quote from: Rex Schimmer on March 29, 2013, 12:54:22 PM
Mike,
Mentally cataloging this.
maguromic
Rex, you are giving all the secretes away.  :cheers: Tony
Dynoroom
We needed to modify the charge-air cooler which had the inlet in the lower center to put it on the lower left. Here are some photos of the unit cut open and the finished inlet.
Dynoroom
Sometime back I posted pictures of the manifold pieces that we had Bob at D & A punch out for us. Here is the basic manifold welded up and just waiting for a bit of port matching & a few mounting holes for the lid.
I went ahead and posted a picture of the current finished part along with what it looked like before assy.
Gman
I wish Bob at D & A would make some parts for our car.  Just kidding looks great.  See you on the salt.  G Man
It's time to stop reading about history and start creating it
7800ebs
G man...
Does this swingarm make this Rearend look small?  lol..
... I know... old parts... "Make new parts"  lol
Mike "Who needs Hogan"  Lefevers
Looks really Good...
Mike and Sons will Rock this year
... and El Mirage is when?
bob
Mike,
As usual beautiful part!!! Your roadster should be taking a "magnum" step up in speed this year..
7800ebs, is that one of Dick Holt's rearends in your car?? Beautiful piece and I like the torque are too.
7800ebs
Yes Sir....
Best Rearend Ever Built...
bob
Please post some more pictures of that car.  Many have not seen it, and it's a treat to look at.  And tell us about your test runs.
7800ebs
Would like to but need to finish it..
will be on the salt...
AND don't want to hijack  Mike's Great post on his Roadster...
see you on the Salt..
bob
Mike,
I would be interested in what the top plate looks like for your manifold, I hope it is either thick or has some "crown" to it plus really thick flanges, at 20 lbs of boost there is a lot of force trying to "balloon" your manifold, especially the top plate.
7800ebs
20 lbs... ?
That's ALL...
Thick plate I'm sure...
try 60 lbs.....  that should balloon it, nicely...   lol
Haas mill standing by with 1" plate if needed..  :-D
bob
Dynoroom
Update on the modified roadster with a fast approaching Bonneville Speedweek.
First, to answer the question about the thickness of the lid on my intake manifold. It will be 3/16" or 0.187 which ever is thicker.   :wink:
If you look at the 2 pictures I posted you will see a couple of fabricated intakes similar to what I'm building. They both run on turbocharged engines. Both of these engines run at Bonneville with over 20 lbs. boost. Both have set many records and both have run over 300 mph. The second one's even run over 400 mph!
From an engineering standpoint the lid should be rounded or bowed, but in the real world that we race in it works fine like this...... for a limited amount of time anyway.  :cheers:
