50cc Sidecar Scooter
Started by revolutionary, August 19, 2014, 10:18:41 AM
revolutionary
I'm excited that the mold for the rear section worked out and we pulled good piece from it today!
Breaking Wind #9614
  ECTA Record AA/BGALT 214.8
revolutionary
Also finished up the mold for the front piece. Easy to see the difference between the first half I did and the second half, after learning some tricks.
Breaking Wind #9614
revolutionary
Okee dokee, got the front piece made and now have to figure out how to mount the thing.  I figure I'll make a little lightweight subframe for it, rivet it on then bolt the subframe to the scooter to make it removable easily.  The rear seat piece is mounted and I'll make a flat bottom tray for it to help stabilize and keep the air from pocketing in there.
Careful welding next to a plastic trashcan full of paper towels soaked in lacquer thinner. Safety first???
Breaking Wind #9614
Just a suggestion- don't use hardware store pop rivets.
grumm441
Quote from: revolutionary on November 14, 2015, 03:10:04 PM
You would fit right in at my work
tauruck
Nice going on the glass work.
It's looking good. :cheers: :cheers: :cheers:
revolutionary
Quote from: manta22 on November 14, 2015, 04:38:18 PM
Good point, they never seem to work as good as hoped - I just ordered a box of wide flange white rivets from McMaster Carr.
Breaking Wind #9614
revolutionary
Let the silliness continue...
Breaking Wind #9614
wheelrdealer
Daryl:
You have as much time in this side car scoot as some people have in a full  blown belly tank!
What we will do for a few more MPH!
revolutionary
And they said the Spruce Goose would never fly...
Got the turbo up and running today. Now I need a longer throttle cable and some tuning time. The intake pipe is a bit ugly right now and I will remake it with some pipe I have on the way. But it feels good to hear it scream at 11k.
https://youtu.be/f02Pn7HoDuA
Breaking Wind #9614
fordboy628
revolutionary
Getting the scooter ready for another trip to Ohio for the land speed races up there. Plenty of work done over the last few months.
Fairings are done and painted. I want to make matching belly pans but that will have to wait.
Installed the Athena big bore kit 72cc. It sounds awesome and I've only ridden up and down the block but think it feels much stronger. Going to the dyno in the next two weeks to get it dialed in. This thing so incredibly loud I don't think it would do to run up and down the streets trying to tune it :)
Also, I have it set up where I can run it as is then swap to put the turbo on and make passes. It doesn't like the turbo until it has been warmed up, but...it does great with it and I got it with a fair enough tune and idle until I hit the dyno.
Pics to follow...
Breaking Wind #9614
revolutionary
Breaking Wind #9614
revolutionary
Breaking Wind #9614
