Parachute release systems
Started by azgearhed, September 22, 2014, 06:49:06 AM
Quote from: Buickguy3 on September 24, 2014, 05:48:48 AM
  Who sells a good coiled cable that can handle a little current?
Doug;
If you use a relay, the current in the coiled cord is minimal.
Speed Limit 1000
Our lakester has 3 buttons on the wheel. I drive with my left thumb resting on the chute button and move it down about an inch to shift gears and then back on the chute button. When I had a problem about .100 of movement had the chute out. The third button on the right side is used when we run nitrous. All of the buttons connect a ground to a relay so with only 4 wires we run 3 switches. When in doubt, hang it out.
Buickguy3
   Thanks, when we were looking for a coiled wire, all I could find was a cord for the handset of an old ATT phone from my shop. Has about three strands of copper in it. I knew there had to be better wires than that.
                   [America]
