'58 RE Indian MPS-750-PF Build
Started by Scottie J, December 07, 2014, 07:25:53 AM
Old Scrambler
All of what the 'Kid' had to say..................and take some mental notes when riding. If the wobble or weave is first felt by you seat and the bars remain steady..........you may have a wheel alignment problem. When riding at speed you might 'test' the bike to see what reaction there is to slightly lowering the weight-center by putting pressure on the foot-pegs.  So far, with two builds accomplished, we have no wobbles............but we spend more time setting the chassis up than tuning the motor :-D :-D.
Scottie J
Thanks guys.  So I'm probably better off leaving the forks and focus my attention on other possible issues?
Old Scrambler
What we're saying is.........don't grab what you THINK is the problem. Start with the basics and eliminate any irregularities. Speed will show a wheel or rim that is not true..........or a tire/tube that is not balanced to the ...nth degree. Burt Munro was so into his motor that he failed to change the original front wheel bearing :oops:
Scottie J
Well, then it must be a balance issue.  Everything else in the front end has already been gone over, except for the brake shoes and bearings.  Both of which have been replaced at some point and are fine.
Scottie J
Hey everyone!  Not much going on in my world.  Haven't gotten a lot of work done to the bike as I've been really busy with work.  I hit a financial wall so I started working part time at the Hot Rod shop I worked at 5 years ago to try and save a little bit more money to put towards the new motor.  So currently, I've just been focusing on making it look good, because I can do that for cheap with investing mostly time and little money.  So, Since I last posted, I haven't done much mechanically except for tune the carb and and adjust timing, and have come to the conclusion that I can't get anymore timing out of the bike on pump gas.  I'm only at about 30* BTDC before it starts detonating under load.  I'd like to get the timing back closer to 32-34* BTDC, factory is 32*.  Also, since converting the clutch to a dry set up, it has not slipped one time.  I've gotten the tire to break loose a couple times in a turn, but no clutch slip, so that's good.
Other than that, I recently finished up the paint work on the bike.  I finally paint matched the new seat pan to the gas tank, and then added some hydrographics to the seat cowl and the primary cover.  They didn't come out perfect as I was using an improvised system for the dipping, but they did come out really good and you can't see any of the flaws from over 5' away.  Anyway, here's what she looks like now.   :-)
I plan on adding some perforated sheet metal to the open areas of the primary cover, just haven't decided exactly what I want to do there yet.
Speed Limit 1000
Looking good. Iwill have to stop by and check it out :cheers:
fordboy628
Quote from: Scottie J on May 04, 2015, 04:11:49 AM
Just a thought here.   Don't get hung up on a number goal for total ignition advance.   Use the timing/fuel strength that prevents detonation, OR, run higher octane fuel that will permit more advance AND suppress detonation.
You really don't have any other choices that will not hurt the engine . . . . . .   IMO
tauruck
There's a nice piece of stainless steel mesh that comes inside the airbag of most cars. I think it's a backing of sorts. You might find hundreds at the wrecking yard.
High_On_Octane
Yeah, I plan on trying some 106 and see what happens.  I just know she accelerates way faster with a bit more advance and less compression.  So hopefully I just need to bump the octane a bit and be ok.  And again, just running this motor until I can build a new motor with better internals.
1000, the bike is at home now in Aurora, but I'd be happy to show it to you.  :)
Tauruk, I have all kinds of blown airbags at work.  Where exactly can I find that mesh?
High_On_Octane
FYI this is actually Scottie, just using my TapaTalk account.  :)
Scottie J
Picked up some perforated stainless on lunch and got it sanded and polished.  I think this should work.  :)
Scottie J
Got the primary cover finished.  Hopefully it doesn't foul anywhere.
Scottie J
Looks like everything clears just fine.  :)
sofadriver
Quote from: Scottie J on March 13, 2015, 07:24:37 PM
If you haven't changed to roller bearings in the steering head you should.  They can really make a huge difference and are inexpensive.   Any bearing store should be able to help you.
Wheel alignment is really important, too.  Try this; use two straightedges (I use 8' fluorescent tubes) bungied over the sides of the rear wheel so they run forward past the front wheel.  Adjust your rear wheel until the front tire is centered between the straightedges.  Perfect! (or darn close to it)
Mike in Tacoma
Bike #833
