My Lakester
Started by No13, March 08, 2015, 07:27:56 PM
No13
a 4" cutoff wheel... then save the spare stuff for the patch work.
No13
Update:  preliminary holes cut for the front spring, spring threaded through the tube, temporarily bolted in place.
Now for the weight of a motor & transmission, cut the hatch, set it in there...  then build the inner mount for the spring.  Yep
This looks well thought-out.
Although I might see an Ackerman problem with the reversed spindles.  But that might be corrected with hitting a bump and the nosepiece bending the tie-rod to correction (or not).
I'd surely double up on my insurance, just in case.
('way back.)
No13
#63
I'll work it out.  It's just fun.... not like it has to steer sharp anyway.  Long way to go.   They're just preliminary holes anyway.
btw, it is not thought out at all.  I wing it most of the time.
bearingburner
Tie rod in front of axle isn't called suicide front end for nothing.
The Chevy 4.3 Truck V-6  a 350 with two cyl. dropped out  has all sorts of speed equipment available  cheap at the wrecking yard also!!!
No13
True, thanks!  But I've got the rear end back enough now... it'll be a V8.  Why not, let's kill ourselves!
No13
Question:  Somewhere I read that sprung axles are required to have shocks.  Correct?
If so, what ideas would anyone here have for this?
Brainstorming here.
Dynoroom
Yes to the first part of your question
they can be old fashion friction shocks they would look cool
Jack Gifford
Quote from: Stan Back on March 22, 2015, 02:23:12 PM... might see an Ackerman problem...
For the limited steering range needed for LSR, I suspect that any amount of Ackerman would work- positive, zero, or negative. [Other than tire scrub while moving around, into/out-of hauler, etc.]
M/T Pontiac hemi guru
No13
Quote from: Jack Gifford on March 22, 2015, 10:29:00 PM
My thoughts too.  I think we'll be fine.  Gimme a bit, we'll get this going.
Next steps, for those that want to know.
1.  Cut the hatch for the engine & trans, set aside to use as mold for the fiberglass engine hatch.  Then use the cut out hatch & other cutouts to patch back up the rear end hole... more on that later.  Gotta keep the structural integrity of the tube...  The rear patch panels could be integrated into the rear axle mounts as well, we'll see what happens.  I dunno yet.
2.  Put junker engine & trans inside for weight (my buddy owns a transmission shop... has some spares I can use)
3.  Drop 50 or so extra lbs into the front it for weight.... and myself.
4.  Build mock up of the inner mount for the front spring in the nose.  Basically, it's a half circle of 1/4 in steel inside the nose with a flat section for the spring mount.
5.  Add spacers until it just barely lifts the tube off the front axle... (sitting/resting in the preliminary notches)
6.  Mark the places things rub or movement is needed.
7.  Pull it all off, grind out the needed areas for movement.
8.  Build the real mount, or just wing it with the mock-up.
9.  Create decent looking inserts/patch covers for the ugly holes out of aluminum, rivet it into place.
10.  Put it all back together.
11.  Hit it with a hammer a few times... LOL.. Makes it look used.
12.  Smile.
13.  Crack a beer.
14.  On beer 2, think about steering...
In my driveway,
Kelly Wood
Bingengineering the shortest route to success!!  :-D
No13
#73
LOL!  Good one.  Bingengineering.  Never heard that one before.
Seriously, I put the tools down when the beer comes out.
No13
Question for anyone that knows. (it's build related)
The wheels I have are the skinny 16" ford wheels.  They're the 5x5 pattern.
My question is: What did these wheels come on (don't say ford... but someone will...) and does anyone know what the hubcaps (perhaps baby moons) came on them?  The nubs are on the inside, not the outside.
I'm sure I'll get some other wheels to run the dishes in the end, but for these, I'm hoping to find baby moons.
Thanks in advance.
