Team Unorthodux, the third year
Started by mergatroyd, March 23, 2015, 09:38:07 PM
mergatroyd
As proof that I am still working on this:
https://www.youtube.com/watch?v=qsHPVvfSl04
The cylinder head nuts were too rusted to take apart, so Ceramic Seal to the rescue. Prior to this test run, I spent a day cleaning the fuel system because I left alky in there. Lesson learned.
Part of the reason it kept cutting out had to do with the fuel pump being flaky... Replaced that with an external one, but now I am waiting on more fuel to get to the store.
I have no idea what I'm doing... but it seems to be working!
mergatroyd
Start with this:
Butcher this:
Build this:
Do a lot of this:
End of the weekend:
mergatroyd
https://www.youtube.com/watch?v=6of2eNBQSFU
Not the LSR bike, but the test of the test bed. I cut out the parts where you get to ogle my ass. :D
Koncretekid
So what is the next step?
If you could fit a good brake to the trailer axle, probably a disc brake, with the brake stay connected to an appropriate sized load cell, you could make it into a dyno.  Just connect the master cylinder on the bike to the brake cylinder to add the necessary drag.  I think Brent DeStoop (sp.?) did something like that down in Australia, but I can't find the photo. There would be lots of heat to deal with, but a Nascar type brake blower might allow short blasts.
mergatroyd
That is the end goal. For now I am going to use it as is. The race bike can be data-logged from the ECU if the laptop is plugged in. It has an EGT probe, too.
Electric drum brake with controller, probably have to add a helper with a spray bottle to mist the drum. Still working out operating procedures... in the video, I couldn't see the controller display, so I had no idea what was going on.
build pics here https://plus.google.com/b/101563515072989515797/photos/101563515072989515797/albums/6311105215895933105
mergatroyd
Aaand, it will be following us to Bonneville... the ECU blew while getting prepped for some troubleshooting runs. Shouldn't run the bike off a battery charger, and should put a smaller fuse in place.
New ECU scheduled to be here on Wednesday.
tauruck
Very cool idea. I love it. Way to go!!!!. :cheers:
mergatroyd
Thanks!
The mailman is adding time on the wrong side of travel...
mergatroyd
#53
And now the coils (race virgins, BTW) decide they are done.  :dhorse:
Not to worry, we have not yet begun to fight...
mergatroyd
The battle was barely engaged over the week.
Things broke, parts were late, tuning was a joke, more parts broke... we made four attempts at decent runs. Nothing worth going past the 1 mile marker. It just wasn't running right.
I guess next year is the charm for this bike.
mergatroyd
I borrowed the fuel pump for a different project, and behold! It doesn't work anymore.
New fuel tank is on the list for this year... something made out of steel.
tauruck
Bummer man. What was the other tank built from?.
mergatroyd
Aluminum plate which isn't too bad... the problem is the attempt to re-use a piece of Ducati cast aluminum as the fuel pump flange. The fuel pump and regulator started out inside the tank, which was fine when it was running on gasoline with the plan to use nitrous. The Ducati piece grows horrible black/grey fuzz overnight. The plate tends to show a little discoloration, but not like the cast piece.
Duck-Stew
Team UnorthoDUX
mergatroyd
It's been a minute since the last update.
I discovered a day or so before Speed Week 2018 that the mystery rev-limiter was due to a missing resistor.
Fresh fuel tank made of steel, no problems other than killing MSD corvette coils like they were going out of style.
No records, but we bumped our personal best by nearly 15mph to 145 and change. I had enough time to look at other M-class bikes and learn some things about "aero" in a non-streamlined class. That was nice.
