Sheet Metal Intake Manifold.
Started by tauruck, April 14, 2015, 12:48:31 AM
tauruck
My Carbon plenum is taking shape.
I've got the top and bottom sections bonded.
It needs some shaping and fettling but I'll be able
to start laying up the multiple layers of Carbon and Kevlar
by the weekend. :cheers:
Pics tomorrow.
tauruck
Pics of the top half under construction.
tauruck
After multiple layers it went into the vacuum bag and then you just
wait for the part to cure.
The little spots are the excess resin that gets pulled through the perforated film.
Pull vacuum too early and you'll get a pump full of goo and blocked connectors. :evil:
tauruck
After the part cured I bonded it to the base.
Some beefing up in the critical areas and then I'll be able to
lay up the good stuff. 14 layers I "guesstimate".
tauruck
I finally had a few minutes to work on the plenum chamber.
First layer of unidirectional Carbon going on.
Many more to go.
tauruck
Wrapping a component like this is a PITA but I have no other way.
I bagged it an pulled vacuum. We'll know later today how succesful
my methods were. :cheers:
tauruck
I removed the plenum from the vacuum bag
and it looks OK.
The bleeder film is still on the chamber in the photo.
I'm busy post curing the resin and I should have pics of
the part over the weekend.
tauruck
I was going to hammer some heavy wall Ally tubing from round to rectangular
for each of the 8 runners.
I did one and it was too time consuming and beyond my capabity so I decided
to produce molds and make the runners in Carbon.
The original is very smooth on the ID. I worked it with flapper wheels to a mirror
finish. The OD has hammer marks etc so I'll use some filler and get to work. :dhorse:
tauruck
The tooling is complex but it has to be done.
I see a four part mold. 2 inner, 2 outer halves.
tauruck
My buddy Ian popped around for a visit yesterday and saw my "wannabee" complex runners.
He asked why I needed to go from round on one end to radiused rectangle on the other??????.
Silly me. :dhorse: :dhorse: :dhorse: :dhorse: :dhorse:
Why?. Why not just go rectangular all the way?. I'll be making changes.
This is what happens when you lock yourself up in the shop and don't see other humans for weeks on end!!!!!!. :-D
We've all been there Mike. Brainstorming with others is a very valuable tool. They don't even have to understand what you're doing. Sometimes a totally different perspective brings out totally different ideas.  :-o :-o :-o  :-D :-D :-D
Dr Goggles
Quote from: tauruck on April 25, 2017, 10:23:16 PM
Staring time. There is no substitute for staring time. And remember, no science is better than bad science....... dometime we so wrapped up that we forget the basics.....
tauruck
Thanks James and Pete. You're both so right!.
My current design looks good but to actually produce the parts
is a PITA.
I can go from the current 63mm ID on the round side to 80.
That will make removing the part from the mold simple.
Attaching the Carbon runners to the manifold creates another
problem so I was thinking of making a wooden buck and shaping
the parts (2) for each runner in Aluminium and get Dunc to weld
them.
Nothing comes easy and I need to take a step back on this. PATIENCE!!!!!
robfrey
I built this intake last year. It was my first sheet metal intake. It was not hard to reshape the tubing to fit in the the square intake. I think it was easier than trying to make them square all the way and I think it flows better. On turbo stuff, the simulation says that a little taper on the runners helps power.
Notice that I built up the entrance to the runners with weld then radius them with die grinder. It was a good exercise for my fabrication skills.
Rob Freyvogel
#496
AA/BFS
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Nice job, Rob.
