Alp Racing & Design Update..
Started by astek, May 01, 2015, 06:54:10 PM
tauruck
Tom, don't pick on the guy. Not all of us are Jockeys!!!! :-D
astek
#46
Tom you are always right, can you imagine how fast this bike would go if I did not have to deal with all things you listed?
Nortonist 592
Quote from: Koncretekid on November 21, 2015, 06:44:12 AM
Alp,
You and your Triumph engine land speed bike are all wrong!
The motor's undersquare  bore to stroke is antiquated
The stroke is too long for sustained high RPM
The hemi head combustion chamber has too much surface area
The camshaft lift can't be enlarged because the cam will hit the tappet guides
The rocker arm ratio can't be altered because the pushrods will hit the pushrod tubes
Even if you could improve valve lift, the exhaust valve would hit the intake valve at overlap
The 2 bearing crankshaft is too weak
Your carburetors are dinosaurs
Your exhaust is too long
Your intakes are too short
Your bike is too high
You are too big for it!  You look like a gazelle on a bicycle!
LOL!!!  Maybe that's where we screwed up.  Instead of trying to do everything right we should do it wrong and go waaaaaay fast.
astek
Here is a list of pushrod engine bikes, I'm not sure what the ECTA numbers are, anybody who knows can add those. But my antiquated engine is in there too. Unfortunately without a fairing at this point.
I heard that the ECTA does not measure/seal the motor so we can run in multiple displacement classes,, If Bonneville does not happen and if I can find a sponsor I may come to Loring which I heard is nice.
astek
My latest land speed racing frame design #2,  less frontal area, lower cd and more of less!!
saltwheels262
Nice looking frame.
And motor plates.
Bf262
ohio -    - 185.076 w/#684
lta 8/14  - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
                            - franey  8/2007
Bookfla
Having run Nitro Methane for many years there's only one rule to follow. Do everything right! Nitro is very unforgiving to mistakes. Congrats on the success you have had.
tauruck
That is a nice frame and anyone that's built one knows it isn't as easy as it looks.
Well done. It looks awesome. :cheers: :cheers: :cheers:
astek
Thank you,
Pictures from yesterdays setup at the Grand National Roadster Show, it started today.
Love the "2 bikes" picture....
really demonstrates both ends of the LSR motorcycle racing spectrum.
Old Scrambler
GREAT COMPANY.............and your both FAST :cheers:
Polyhead
Quote from: saltwheels262 on January 06, 2016, 05:14:54 PM
Nice looking frame.
And motor plates.
Bf262
No kidding, that looks amazing.  I love the cradle/brace for the engine.  I wonder what that does for modulus of the crank case.  Sure can't hurt!
Ben 'Polyhead' Smith
  KE7GAL
astek
Great News!! This is very important to us.  I can proudly announce that we made an sponsorship deal with Kibblewhite Precision Machining.
tauruck
Great news Astek. I'm sure that will help a lot. :cheers:
Wish you all the best. :cheers: :cheers: :cheers:
BTW, I can't open the image you posted.
