Methanol Or Ethanol Staarting from scratch which one is best?
Started by rouse, May 20, 2015, 08:53:40 AM
bearingburner
I'd go with ethanol preferably Jack Daniels. You could always drink it it if the engine blew.
Dr Goggles
Great thread, and the interesting thing?.... E85 don't cost as much as some of those other speciality products.........
rouse
The JD sounds like it be the call, but it has to much water :-D
I will run E85 starting with E98 and blended, that way I'll know what the 15% composition is.
Racers spend to much time, effort, and $$ to just roll the dice on fuel mixtures that are inconsistent as E85 tends to be.
I am supposed to be getting parts for the build coming in this week and we'll build to that Fuel.
Rouse
Johnnie Rouse
TheBaron
As an old air racer crew chief that had to deal with water/alcohol injection, I know what the military research found out as far as the best alcohol for combustion properties,,,,,,
METHANOL
Robert "Smitty" Smith
rouse
Quote from: TheBaron on May 26, 2015, 08:40:28 AM
METHANOL
I agree Smitty, however, at this point I have to much momentum headed in the wrong direction for methanol.
Ie. the injectors, heads, ports, are all sized for E85.
Rouse
Johnnie Rouse
hotrod
Actually when they did comparative testing ethanol and methanol were interchangeable in ADI (water injection systems) in high performance WWII aircraft engine applications.
They used a mixture of methanol and ethanol in very low temperature environments to get the high concentrations of alcohol they needed to achieve freeze protection and best performance.
The only reason they used methanol was it was poisonous so the GI's were not likely to steal it and drink it. It  is also cheaper to make and untaxed. During the research at Pratt & Whitney, they got a supply of high proof ethanol for testing and they got a tank car escorted by U.S. Treasury agents who were worried about it being diverted to "medicinal uses". Remember this was shortly after prohibition ended.
The Navy used ethanol for their torpedoes (so called torpedo juice) because it was much less toxic than methanol and just as effective in the torpedo motors. They did have problems with the swabbies skimming some off to spike their punch.
Best easily available document on the development of water alcohol ADI systems for high performance aircraft is probably this PDF.
http://www.enginehistory.org/Frank%20WalkerWeb1.pdf
