The Electric S10 build
Started by d55guy, May 29, 2015, 08:55:48 PM
d55guy
More pictures
I really do like your idea of quality family time. The kids should be included.  :-D :-D :-D
tauruck
Even better. I like the ear muffs :cheers:
You should be complimented for that.
d55guy
Quote from: Peter Jack on June 03, 2015, 08:52:55 PM
Quote from: tauruck on June 03, 2015, 11:26:17 PM
Thanks.  I can only take partial credit for the muffs as I didn't even need to ask him (I try to teach him right).
BTW I paid for my motor controller last night and it should be here next week.  I'll post pictures when I get it, but the amount of power I am going to have on tap is....  unhealthy.
I also ordered a 91 trans am axle and it will be here tomorrow so I can start fitting that in.  I think I will end up having to narrow it with new ends and axles to fit under the skirts but it already has 2.73s and a limited slip. I think it's a zexel torsen in a series 2 carrier but I won't believe it until I pop off the cover.
Kerry
Kerry
Frank06
Which one did you end, up with?
E-Racer
krusty
Cool build. What shade of green are you going to paint it? :-D
Quote from: krusty on June 05, 2015, 01:49:07 AM
Hmmm.... Saylent Green-- wasn't that a movie starring Charleton Heston?
d55guy
#22
Quote from: manta22 on June 05, 2015, 08:37:53 AM
Regards, Neil  Tucson, AZ
Soylent green.  You guys are hilarious. :-D  I didn't think about Soylent.
Sylent is a nod to the s10's super cool brother the awd Syclone.  But when I talk with my aero friends (I used to design GA aircraft ) it has taken the name "The Quick Brick"
 I am going all satin black.  There is a guy in town who will dip it for 500 bucks.
Quote from: Frank06 on June 04, 2015, 07:12:08 PM
As far as the controller.....  it is shipped and will arrive next week. ..  :)
Kerry
tortoise
Beautiful project. Two questions:
Why AWD? At your projected speed, you won't be traction limited.
Have you considered an tapering aero bed cap?
Frank06
You got the Shiva I saw on DIY, right?   :cheers:
E-Racer
d55guy
#25
Quote from: tortoise on June 05, 2015, 10:36:11 AM
AWD:  Well axle and motor limitations.  I am worried about how much power I can put through the 7.5 10 bolt and how much sustained power I can put through the 2 warp 9s for longer then 10 seconds.  I am thinking of powering the front axle with a 100-200kW AC motor.  It has a higher RPM so the 3.08 ratio will be okay.  But that is phase 2 of the build.  It will be rwd for now.
As for the cap: Yes. See attached. CFD is in progress.  I wanted the long bed so that I would have a smaller diverging angle. With the shorter bed it
is 15 degrees which is borderline at this Reynolds number.  I'll see what the CFD says before I start building.
Kerry
d55guy
Quote from: Frank06 on June 05, 2015, 02:43:31 PM
Yep.  :-D  This changes the direction of the project a bit.  Before I was going to be limited to the 400hp of the Soliton1.  But since Evnetics stopped production of it I had to go another route.  In the end I found I was able to get the *used* 1600hp Shiva for a little more then the new price of a Soliton1.  I did designed that battery pack so I could easily double the size. And I do have 2 more volt packs That would give me another 700hp for another 600lbs of weight over the rear wheels.   :evil:
Kerry
Finallygotit
Dan
Tucson, AZ
salt27
Kerry, Have you looked into the aero mods done to the GMC Syclone that set records at Bonneville?
Very interesting.
With a satin black body you may need air conditioning.   :-D
Thanks for sharing your build, Don
d55guy
Quote from: salt27 on June 05, 2015, 05:19:03 PM
Very interesting.
Hey Don, I have seen pictures but nothing more.  Do you have a link to more information on the Syclone LSR?  My goal is a Cd of <.35 which I think is pretty doable, it's the lift coefficient that I am more worried about. :)
As far as the AC at least it's a short run.  I used to road race in a all black C5 and yeah.... in the summer it gets uncomfortable fast.  Especially with all the safety gear on.
