How exactly is a "measured mile" measured?
Started by fjlee, October 25, 2015, 06:22:07 PM
Elmo Rodge
OK Tony. So how do you lay out the 1.3 mile course at El Mirage?  :roll:  :cheers: Wayno
dw230
How long have we been using 1.1 miles at El Mirage? Do we have to toss all the records set since that date?
F104A
The accuracy of time is 20 nS (.000000002 seconds), So we can discount that error.
The accuracy of position is within 3 mm, regardless of distance. For two points that increases to 6mm, or .23622 inches, or +/- 0.000001864 miles.  This includes any change in altitude too (which traditional systems don't do)
200 mph is 1 mile per .005 hour
1.000001864 miles / .005 hour is 200.000372 miles per hour
0.999998135 miles / .005 hour is 199.999627 miles per hour
so the answer is +/- 0.000372 miles per hour
800 mph is 1 mile per .00125 hour
1.000001864 miles / .00125 hour or +/- 0.00149 mph accuracy at 800 mph.
fredvance
Wow!
I'm feeling great!  We're nearly breaking records set at 1.3 miles.  Another 1056 feet and we'd be there.
Elmo Rodge
Jack Gifford
M/T Pontiac hemi guru
jacksoni
Jack Iliff
G/BGS-250.235 1987
G/GC- 193.550 2021
G/GMS-182.144 2019
G/GCC- 194.580 2025
jacksoni
Quote from: F104A on February 04, 2016, 02:01:39 PM
Yes, but as everyone will say there is a big Acura difference between 199.999627 and 200.000372. :cheers: :dhorse: :dhorse:
Jack Iliff
G/BGS-250.235 1987
G/GC- 193.550 2021
G/GMS-182.144 2019
G/GCC- 194.580 2025
Quote from: jacksoni on February 05, 2016, 05:09:26 AM...Yes, but as everyone will say there is a big Acura difference between 199.999627 .....
...if I had only done this.....
Quote from: jacksoni on February 05, 2016, 05:09:26 AM........ and 200.000372......
... a big smile and a vist with Dan  8-) 8-),
Malcolm UK
#70
Quote from: TrickyDicky on January 12, 2016, 02:29:27 PM
Quote from: tortoise on January 12, 2016, 12:38:39 PM
Quote from: TrickyDicky on January 12, 2016, 11:44:11 AMA record is not measured to 0.001 mph.  Although record speeds are reported to three decimal places.  The measured parameter is time, which may be recorded to many decimal places but is then truncated to 3dp for (FIA) record purposes.
Hmm . . .
So if you're timed at 7.2009 for the mile, which figures to 499.9375 mph, you'd be credited as going 500.
Yep.  It needs someone smarter than me to explain why this is considered to be the "correct" way to do the calculation.
Not sure if the rule book helps, but the FIA rules follow. At no time could 499.9375 be anything greater than 499.937.
FIA D12.3.2 Time accuracy. Record time with an accuracy of 1/1,000th of a second and calculate the mean time with an accuracy of 1/1,000th of a second with no rounding off.
FIA D12.3.3 Speed Accuracy. Calculate and record speed with an accuracy of 1/1,000th of mph or kph
FIA D12.3.4 Conversion. Convert speed thus calculated to kph or mph with no rounding off using the defined conversion factor.
FIA D12.3.5 Precision. If the timekeeping equipment has accuracy greater than 1/1,000th of a second, its precision shall be set to record times to 1/1,000th of a second with no rounding off to allow direct use of all readings.
Malcolm UK, Derby, England.
TrickyDicky
Quote from: Malcolm UK on February 05, 2016, 01:54:57 PM
Hmm . . .
Malcolm, I think tortoise's point was that if you apply the above rules then 7.2009 rounded off becomes 7.200 and, hey presto, 500 mph.
PorkPie
Quote from: Sumner on February 05, 2016, 07:40:37 AM
Sumner,
I think you taking about the very exclusive 199,5+ mph club at the salt....for a short time I was also a member of this club.....but may be they ask Betty Burkland...she had this experience for 15 years....she run 199,997 mph.....before finally she could get her red hat....
Malcolm UK
Quote from: TrickyDicky on February 05, 2016, 03:34:49 PM
The figure of 7.2009 is never 'seen' by the FIA timekeeper as the rules are written. The fourth decimal place is just ignored.
Not sure how you could ever arrive at the average or mean time being 7.2009.
tortoise
Quote from: Malcolm UK on February 06, 2016, 01:04:08 AM. . . The fourth decimal place is just ignored.
Nonetheless, our notional vehicle is actually going less than 500 mph, but is credited with that speed.  Not a big deal, just a curiosity.
