9" Ford
Started by azgearhed, February 23, 2016, 01:59:01 PM
Bob Drury
  Willy, are You sure?  I have never heard of a taller gear for a 9" than a 2:47.
                                                         Bob
p.s. I am sending You a p.m. on another matter...........
Bob Drury
salt
I'm sure, Bob - it's one of a dozen or so sets made by Roush a few years ago.
Willi
Who Has More Fun?
Bob Drury
  Man-o-man, that thing must have a pretty thin ring gear and one hell of a big pinion! :-o
Bob Drury
geardaddy
Quote from: azgearhed on February 23, 2016, 01:59:01 PM
Wanted-9" Ford 2.47 gear set -Tim 602-980-2924
I have some 2.47  and 2.50 gears for a 9 inch ford........best to call me...612-309-3999...612-309-3999
fastman614
Quote from: Bob Drury on June 06, 2016, 07:04:55 PM
                                                         Bob
Bob - I came across this and wondered the same...I know that there was also a 9.5" rear axle that went into big Lincolns and Mercurys - as well as Ford Trucks in the 70s and maybe more recently.....Sparky turned me on to this....The Lincolns for sure  and maybe some of the bigger engine Mercs had as an option a 2.29 gear ratio....Very few of he parts for these 9.5 gear ratios can be interchanged with 9" diffs...The whole center section has to be used and they came only with 31 spline axles....they do bolt into a 9" housing but the flange has to be relieved some both top and bottom to clear the ring gear....
What I do know about some of these "oddball" gear ratios is that Richmond Gear and others made many special ratios for 9" Ford diffs - Now - if only I could find some fill in the "huge" ratio gap between 2.75 -1 and 2.50 - 1 - although I DID find a super rare set of 2.69 - 1 gears for a Ford 9" rear end......
bearingburner
The only ratio I ever heard of for the "91/2"  was 2.78.
