Drag coefficient fundamentals
Started by Jack Gifford, November 14, 2016, 10:42:49 PM
Bratfink
Quote from: Stan Back on August 29, 2017, 03:48:47 PM
This'll show you how sophisticated I am!
Whataya think about testing models in a captive hydraulic environment by measuring the overall pull of the flow?  (Huh?)
Water tunnels (or tow tanks) are an excellent way to maintain the Reynolds number in small scale without having to flow at very high speed. Essentially increase density instead of velocity to balance the dimensional equation. To save power many of the older water tunnels were gravity fed, as in the x plane of the test section was vertical.
Here's the problem; friction coefficients (viscosity) for water are much higher than air. Thus wake distortion, separation points and some other things behave differently to how they would in air. Still a valid test form though.
Bratfink
Quote from: jacksoni on August 30, 2017, 06:05:25 AM
Here is the youtube link. This is the first of maybe 8 or more videos this fellow made using his water tunnel to illustrate flow around several cars. An accurate model is needed.
Yup, this is like what I was talking about. However, I wouldn't describe that as an accurate model. No cooling pack, no open grilles, no open wheel arches with rotating wheels, no underbody detail, no cut line sealing. All of which have an impact on the aerodynamics. But this is a great tool for basic shape development.
We actually do flow visualization similar to this in the wind tunnel but it requires lasers and high speed cameras. And what can't be made better by using lasers  :evil:
Bratfink
Quote from: manta22 on August 29, 2017, 04:13:59 PM
Stan;
I thought about that, too. How about letting a model roll down an underwater ramp and timing how long it takes to travel between two marks on the ramp. It won't give you quantitive data but it should show up differences between model shapes. The bigger the model the better.
Why not do it in air? Simple Coastdown testing. Run it up to speed, shut it off and shift to neutral see how long it takes to stop. You have to be careful to keep all the variables as constant as possible, but people do use this method.
I proposed doing it with a model, not a full-size vehicle. It is far easier to evaluate different model shapes in a swimming pool. Yes, I know people use a "coast-down" test but that is using a car that is already built.
Bratfink
Quote from: manta22 on August 30, 2017, 08:18:49 AM
For shape development that is defiantly an option.
jacksoni
Jack Iliff
G/BGS-250.235 1987
G/GC- 193.550 2021
G/GMS-182.144 2019
G/GCC- 194.580 2025
Bratfink
Quote from: Stan Back on August 30, 2017, 02:35:51 PM
Is that defiantly or definitely?
ha ha "defiantly". I didn't notice auto correct changed that.
The "defiantly/definitely" error is a very common one I've seen countless times, so maybe it is an auto-correct problem.  This validates my feeling that auto-correct/auto-spell software isn't the end-all that'll make proofreading obsolete.
Thanks for letting us yank your chain.  Stan and I defiantly enjoy the exercise. :cheers: :cheers: :evil:
floydjer
Gosh Jon, Ewe keep picking on the gnu  guise and their going two go aweigh................... :wink:
