Quickchange horse power drain
Started by ronnieroadster, December 06, 2016, 01:18:21 PM
John Burk
It's easy to calculate the efficiency of a rear by how hot it gets and converting the heat into hp . If a rear is 70# steel , 15# alum. and 4# oil and it gains 35 deg. during a 1.2 minute run that's 393 btu / minute that converts to 9.27 hp . For 600 input hp that says the rear is 98.5% efficient .
How much air flow did it have on the run?
Was the cover finned aluminum?
Did you use a pump and cooler?
. . . and whatever.
Feed those into the sliderule, too.
John Burk
This hypothetical car is a lakester . No air cooling .
Frank06
No way it is 98% efficient.... chain drive isn't even that good.
E-Racer
John Burk
Rears would be over 200 deg. after a run if the losses were 5% .
kiwi belly tank
Quote from: Frank06 on December 09, 2016, 05:28:50 PM
Ditto on that one!
John Burk
Do the math . It takes .12 btu to heat one # of steel one deg F . Alum. is .22 btu . Oil is .45 .  42.4 btu / minute is one hp .
And nothing radiates the heat between measurements?
I'll race with a Dream Wheel, but a computer is beyond me.
Ron Gibson
Amazing how many people ask "what's a Dream wheel?". I tell most of them, it's a slide rule for cars. :-D :-D
Ron
Stan;
At relatively low temperatures very little heat is lost by radiation. At the temperatures John is talking about the radiant heat loss is nil.
Interested Observer
While the temperature measurement method is sort of an elegant way to estimate power loss, it is, like many things, fraught with generally unmeasured variables.  And recall that the example in the beginning was just based on arbitrary quantities of the weights, time, power etc.
In addition, varying convective cooling, some radiant loss, non-constant application of input power, uneven temperature distribution within the gearbox, and so on.  It can be done but a lot of stuff needs to be carefully measured to generate a valid result.
Frank06
Quote from: John Burk on December 10, 2016, 12:37:11 PM
The math seems good, but where does the 35 F degrees come from?  I would stick with the 4-6% cited in one of the tech articles.
It is an interesting method to calculate losses though!
E-Racer
ronnieroadster
 Interesting stuff heat transfer air flow over the housing way to many variables the way I see it. Looks like a simple percentage is not an easy figure to determine. SO
   Taking into consideration something Stan said. Using the wonder wheel I have from Mark Williams the calculated speed based off tire diameter, gear ratio and RPM came out perfectly to my top speed recorded.
Go figure.    :dhorse:
kiwi belly tank
The question was never about gearing & speed, it was about power loss through a QC & I think Dynoroom's numbers are realistic. I know your engine is at the ragged edge & you're interested in getting more of it to the wheels so I would suggest you build a 7.5 10 bolt & give it a shot, even make it a bolt in so you can switch them to see the difference. S-10 housing is probably about the right width. I think I have a 2.56 & I know I have two sets of 2.41's & I think you could use a bigger gear.
  https://www.youtube.com/watch?v=hMy8nGYOOrk&t=248s
My comment was really about feeding in the data.  My old cardboard's answer is within a MPH at 200-speeds at Bonneville.  I'm thinking that all the factors fed into a computer that comes up with an unbelievable number is missing something.
