Wheel Rules
Started by Harold Bettes, October 17, 2006, 05:14:42 PM
Harold Bettes
Thanks to all that have shared advice.
Thanks.
HB2
jimmy six
Can't answer on the bias to radial..
I have run both tubeless and tubes depending on the tire. It has been my experience that the GY front runners do not like a lot of pressure on the side walls I would advise tubes in these tires. Dunlops are tubeless and I have run them both ways with no problems.  A Dunlop 18 @32" can use a 17.5" tube from of the old style pickups of the 60's with ease. I like a tube with steels stems and they can be found on the net with alittle looking, both angle and straight stems....Good luck
