Source for "Premium" bolts other than ARP?
Started by SteveM, December 20, 2016, 01:21:32 PM
Crackerman
I hate even thinking this... But if you cant find those anywhere, fastenal can make you some. They won't be cheap, i was quoted 60 bucks each on an oddball m13x1.25, depending on what its used for, tap out to new bolt size, or helicoil, and use a standard available not m
maj
#16
https://www.belmetric.com/10x10-extra-fine-c-6_339_359_907/
I would get the 45 and or 50 and cut to length so you have a shoulder to support the flywheel
SteveM
Great discussion, guys!  This kind of topic highlights why the Landracing.com forum is so valuable.
Through good fortune, someone contacted me directly with a set of connecting rod bolts from a premium manufacturer with specs that will work perfectly for my application.
The internet is great!
bearingburner
Bolt depot list 10MX1.0 cap screws in 10.9 grade in various length for about $ 1.00 each
SteveM
I ordered a set of 12.9 socket head cap screws from McMaster for mock-up purposes.
Depending on the rest of the varaibles in this setup, I may continue with the McMaster bolts, or use a set of connecting rod bolts from a different application.
steve.
