200MPH Vintage Class Bike Build
Started by astek, December 22, 2016, 01:22:51 AM
Koncretekid
astek
Quote from: sofadriver on February 23, 2017, 10:26:19 PM
Alp, what about engine cooling?
The bike will run in the fuel class. Nitro, the fuel itself will keep it at a certain temperature.
Quote from: Koncretekid on February 24, 2017, 05:08:32 AM
X-ray vision??? :-D
Just got my polycarbonate sheet, no x-ray vision here! :)
stay`tee
[/quote]
Yes, Methanol will cool it, but, what percentage Nitromethane are you planning to run  :?
Calkins
Quote from: stay`tee on February 24, 2017, 10:50:31 PMYes, Methanol will cool it, but, what percentage Nitromethane are you planning to run  :?
He didn't say anything about running alky in it...    :-D
astek
My engines are running on 96-98%, there are a few things I have to figure out with the APS engine. It is not going to be the same configuration (reverse head, different exhaust ports/pipe design and some other stuff).
Astek said:  "...My engines are running on 96-98%...".
Whew.  Start out with just a little and save the heavy load for after you get the tuneup right. :-D
astek
Koncretekid
Impressive, Alp.  And I thought I was a "Jack of all trades", but here is a skill I've not even begun to attain.
I may have to bump my motor up to a true 650 and find another 50 hp to stay in this ballgame!
astek
Thanks Tom,
almost done with the rear pannels
astek
sofadriver
#101
Alp, I just sent you 2 PMs.
Mike in Tacoma
Bike #833
thefrenchowl
Nice bird, Astek,  :-o
but isn't the front 180 degree fender supposed to be separate from the main fairing?
Patrick
astek
Quote from: thefrenchowl on March 19, 2017, 02:58:37 AM
Patrick
Thanks thefrenchowl,
My fender is separate from the main fairing, but my design is different. Everybody puts their fender under or inside the main fairing, mine is on top of the main fairing, it is also less than 90 degree.
salt27
Will you be running SCTA or BMST?
Beautiful body.   :cheers:
