Best Undercarriage Protection Against Salt
Started by ggl205, June 03, 2017, 09:38:20 AM
RidgeRunner
     Thanks for the real deal link SD.  Now I know finally know why the stuff was so hard to clean off the tools and parts over 50 years ago, they had probably been stored within the stuff since at least the end of the second big one -20 years at least.  Such a pain to take off then I've avoided it since.
Dr Goggles
Quote from: thundersalt on June 06, 2017, 12:06:35 PM
I used salt x for years. It works better as a cleaner after the trip. Last year I bought bulk wd40 put it in a sprayer and lube up every nook and cranny. I was even covered with it. Worked better than anything I used in the past. Also it helps with all the bare metal parts on the newer trucks.
That's my tip for the race vehicle. Also we've all had that issue where you get home after the salt and all your thrash time and then time away has conspired against you and it's all hands on deck for anything and everything EXCEPT the race car. It takes ten minutes at most to go out to the shed and give the car a hosing in WD40, if you go out a few days/weeks later and there's still water clinging to it, go at it again....
For the tow vehicle I tried silicone spray lubricant one year, emptied a big can on the whole underbody, NOTHING stuck to it, not even dirt, I have also tried others like WD40 but the silicone was the best....however WARNING: it is best used in a contained situation, I wouldn't use it to douse the race car because it is persistent and very slippery...
One thing about spraying silicone on everything-- don't do it if you ever plan on fiberglassing anything on it or bonding something on with epoxy. Silicones are a good mold release so it will prevent anything from sticking to it.
Elmo Rodge
Neil, actually they're a terrible mold release because if you ever want to bond anything that's been within about three miles of the stuff you're skeeeerooood.  :roll:
Wayno
I think that's what I said, Wayno.
sofadriver
Bought this at the auto parts store.  Sounds pretty good.
http://www.fluid-film.com/
Mike in Tacoma
Bike #833
Smearing on a thin layer of that blue waterproof boat trailer wheel bearing grease works pretty good.
mstrdinan
seems to me I read somewhere that a nice pair of FOR SALE signs is appropriate after a few years on the salt....
BHR301
If you live in the rust belt (Michigan) in two or three years it will look like every other car or truck.. :cheers:
jimmy six
donpearsall
If you take any vehicle on the salt no matter what precautions you take, it it is doomed. You can coat the underside with whatever you want, but salt dust will get everywhere not just the bottom. The salt particles are suspended in the air all the time, salt water splashes everything, you will bring it into the cab with your shoes and clothes.
The only solution is to make vehicles out of 100% plastic or ceramic and not have a bit of metal in it. Maybe one day...
racergeo
  Get a roll of Gorilla tape and make some over size wheel well "salt flaps" for rear wheel wells. F@R.  Cover carpet w/cardboard and tape to the sill plats. Spray Blaster brand penetrating catalyst (Home Depot) on your Ebrake assy. and your brake pivot. WD40 under your dash. Then saturate the under carriage, especially where salt is flung off your tires with Blaster brand corrosion inhibitor. Home Depot will sell all these items 5 cans of the Blaster products and the tape for under $30. Then pray.
I was thinking about the rental that I drove to the salt in '15.  I rented here in Marquette where they didn't have a clue, and when I returned it I spent a few bucks at the car wash rinsing off the most visible of the salt.  I had rented it from a branch at the local Ramada Inn -- so upon returning it I left it way over there in the lot and hoped they'd move it before the next rainstorm.  It was still dripping lotsa salt when I walked away.
Did you happen to buy a black Chevy Cruze from Avis a year or so ago?  Has it dissolved yet? :roll:
