Bockscar 2.0
Started by Stainless1, October 03, 2017, 07:59:00 PM
Jack Gifford
I must be missing something- it looks to me that it will behave like an infinitely-stiff anti-roll bar. :?
M/T Pontiac hemi guru
should limit individual wheel travel I would think
Jack, is that a bad thing for a car built to only go straight?
We had a 4 link with a panhard bar, on a very narrow car, the bar was really short and suspension movement up and down also caused right and left rear steer... not a lot, but enough to make the car wander.
We changed that to a 4 link with triangulated top links, that eliminated the movement and made the car more stable but the rough courses of late caused a little bit of body roll and that made the drivers a bit uncomfortable.
Looking at some cars on the salt, I noticed some commonality, a lot of the Special Construction cars basically had a swingarm rear suspension.  That pushed me this direction... if it ends up not working, I will rebuild it with something else.  I can tell you there is no sideways movement, and no flex in the entire setup.  Both wheels will move together, and the coilovers will control that.... with any luck.  Hoping it will be a lot like having a solid rear, but with some suspension movement.
Any suspension guru's out there what to chime in?   :cheers:
How about using a Watts linkage to control rear axle lateral movement instead of a Panhard bar?
Koncretekid
#349
Quote from: Jack Gifford on October 27, 2018, 10:28:54 PM
No suspension guru here, but I agree with Jack, but I don't think that is a bad thing on a narrow car.  That being the case, I would box up the two arms to make sure there isn't any flex side to side.  Otherwise, I think that 1" x 2" cross bar will take a sh*t kicking and may crack at the welds as one side tries to move independently from the other.
Sort of like a motorcycle - - You want to make sure the swing arm is stiff enough not to twist!
Neil, I'm thinking the way its made it is it's own lateral control and should not need additional lateral control.
Tom, not expecting a lot of twist flex... the coilovers will attach to the old 4 link mounts above the point that has the three 1/2 in bolts that hold the 5/8 steel plates on the swingarm to the axle... Not a lot of twist allowed, but we will look at it after it is built to see if it needs more stiffness added.
Jack Gifford
Thanks for explaining your approach. I sure can't argue with "surveying what works". If my lakester doesn't have enough room for a driveshaft and U-joints, I may consider a similar scheme- but having the engine/trans/rearend as a sprung unit.
Stainless,
If you find that your swing arm requires more twisting stiffness I would suggest that you weld in an X member out of some 1 x 2 tubing and make the 2 inch section vertical. X members resist twist by bending so you want the largest section vertical.
Started bending tubes for the back of the car.  Bent the curves for all 4 with John Goodman's (ggl205) tube roller.  I will need to do the compound curve up for the bottom back.
Ross (mc2032) was over and suggested that I build it upside down because it will be easier than suspending these tubes and then trying to bend the tubes up to meet them and keep everything in the right place.  So these are the top tubes, they are just being built on the bottom.
BJ Burkdoll suggested it would be just short of impossible to do all the compound curves in one piece, but if I cut the curve where it starts to rise, bend that part, clock it where it goes and then weld it back in it might be easier to duplicate.
But before I can do that I need to figure out a chute tube.
tauruck
You've got some "good" guys assisting there.
The project looks awsome. Your shop is so tidy.
I wish I could say the same.
Building the rear clip upside down makes sense IMO.
Great progress. :cheers:
floydjer
I spy an orange fitment device...Looks great Bob.
Mike, if you saw the entire space, you would not consider my shop "tidy"  :-o  although I did clean up a little and put some stuff away before I started bending because I had to turn the car around because I couldn't reach the back of the car with the TIG.  Ross and I rolled the car outside through the big shop because there is not enough open space to spin it indoors.
Jerry I could have used this pic to get you a better view of El Kabong... also added a refresher course
Stainless,
Have you ever thought of just making the top and bottom tubes the same and parallel in side view and not have the rear bottom come up? We were planning to do the rear of our car with both the top and bottom come together to form a point this would make the rear body have a continuously decreasing diameter, i.e. a NACA 66018 cone. I talked with Woody regarding this and he suggested that we retain the NACA shape in the plan view but make it a constant dimension in the side view. Except for the slight increase in skin area the aero is about the same. It also forms a fairly large side view area which moves the center of pressure back.
Rex, I will have to consult my Aero guy on that, but to answer you question, I had not considered that.  The car was designed as a streamliner in the 70's.  It turned into lakester in 84 with the tread layouts recommended by the same guy.  Several years later he suggested a nose job...
Tom Burkland  asked me if I was going to build a new car, I said yes.
Then he asked if I was going to change the shape and build a fast car... told him I hated to screw with success but I was hoping to make improvements as I went along... He is not a flat bottom car fan....
The car has changed a little over the years.... I think our first record in 1984 was J lakester in the  low 130's .  :cheers: :cheers:
Stainless -
I was aware that the Bockscar had undergone some reiterations over the years, but I was unaware it had started out as a streamliner.
That's a very cool set of pictures, and a really good example of project development over a number of years.
This new one is going to rock.
Carry on, chief.
