New Vintage Project, 250cc M-VG, Reconstruction of a 1933 French Jonghi 350
Started by thefrenchowl, January 03, 2018, 09:56:52 AM
Patrick;
I wonder if this would keep the lead weights in place:
1. Clean the ID of each hole.
2. brush flux on the ID of each hole.
3. Cast the weights with 63/37 solder.
The solder should create a bond with the crank counterweights if the counterweight can be brought up to the melting point of this alloy, 361F.
thefrenchowl
I like your thinking, Neil,  :-D
I'll have a go, but the tinning of the the inner walls might bond with pure lead anyway?
Patrick
Ron Gibson
I think the pure lead is way softer and will have a tendency to distort or flow more even if it is bonded to the holes. You can take a stick of 70/30 body lead and hang half of it over an edge. In time it will bend completely down under it's own weight.
Ron
Quote from: thefrenchowl on June 15, 2018, 04:38:21 PM
Patrick
Patrick;
The reason I suggested using a 63/37 solder alloy is that it has the lowest melting point of any solder. Easier on your crankshaft.
thefrenchowl
Thank you both, Neil, Ron, for the advise...
This is the lead I have, roofing lead...
I bought a roll some years back when I repaired some of my roof that had a few broken tiles...
Would that be pure lead? It's very soft and easy to fashion...
The roll was round when I bought it!!!
Now collapsed under its own weight!!!
Patrick
bones
Hi Patrick
  Re the lead weights in the crank. Can you get hold of some "mallory metal" and turn the weights.
then press the pieces into the crank holes.They won't go anywhere. It's a carbide based metal that is machinable.
Also with the big end. If you have to replace the big end pin it would be a good idea to get rid of the crowded roller
setup. You should be able to find a caged big end bearing , with a silver plated cage preferably.
   cheers    Bones
thefrenchowl
Whaooo, we're getting somewhere!!!
Never heard before about this mallory alloy, that's what I love about this forum, lots of guys with slightly different perspectives and backgrounds, so plenty of proper advise given...
This is what I found about densities:
Iron: 7.87
Lead: 11.35
Mallory alloy: from 17 to 18.5
I did my 1st Jonghi 3 years ago with lead, despite not liking one bit the shape of the slugs that came out of it...
On this one, the slugs were moving about quite a bit but their weight is pretty consistant within 5 grammes which tells me none of it departed towards the bottom of the crankcases.
So I have a good reference for the weight to be added, rather than just fill the holes flush.
The big end and ancillaries are perfect, I'll leave them as is at this stage.
Just a bit of work, filing and polishing, to clean up the rod...
I also have a full set of NOS replacements, rod race, pin, nuts, rollers in a jar full of oil...  :-D
Thanks again!!! Well appreciated!!!
Patrick
thefrenchowl
Busy weekend ,
I'll leave the crank alone while I investigate this Mallory alloy....
So, instead, I started the second petrol tank cap... It went better than I thought it would... (sommat bad bound to happen soon...)
In them days, these english caps came with four different levers, the flat one as shown, the basculing lever as on Sarolea Gregoire "monotube", the Brough Superior version with three balls and the Jonghi one with just one ball.
Today, only the flat lever is available...
I'll do the Jonghi version later, much classier!!!
So long,
Patrick
ggl205
Quote from: thefrenchowl on June 17, 2018, 03:14:35 AMNever heard before about this mallory alloy, that's what I love about this forum, lots of guys with slightly different perspectives and backgrounds, so plenty of proper advise given
Mallory metal (also known by several other names) is just a tungsten alloy used for balancing cranks. Easy to tack weld too.
Quote from: ggl205 on June 17, 2018, 09:09:06 AM
Expensive too!
thefrenchowl
I'll see the costs when I find a supplier!!!
I finished yesterday by taking off the knee grips steel holders.
They'll be reused later once the tank extension is done. Plus a few rubbers to insulate the tank from the insane power of this engine  :-D
So long,
Patrick
Patrick, you can heat the crank in a kitchen oven to around 450 degrees F.  Then, pour the lead in the holes.  The crank will cool and contract around the lead and this will help to hold it in place.
WW;
If he uses a flux, the lead will be soldered onto the crank. No shrink-fit is needed but it will help.
thefrenchowl
Hi,
I could do a lot of things with lead, but thinking about it, that's all they had as heavy metal in the 30s...
The std street Jonghi side valve was given for 4500 rpm...
The carb, cams and overlap of TT 2 should see its revs rise to well over 6000rpm, a 33% increase and centrigugal force rises at the square of the rpm.
Loads more strain...
I know the Jonghi racers had a different crank arrangement, but no photos or drawings have been found so far.
So, faced with using the street crank, I fancy improving it a touch!!!
Thanks again to all for the to and fro, it helps narrowing down the solutions.
See ya all,
Patrick
thefrenchowl
Bit more done this afternoon after work: Air vent fitting for the tank...
Patrick
