Simpson Arm restaint ... Does it meet the new rule?
Started by QikNip, February 07, 2018, 01:05:53 PM
deep in debt motorsports
My G-Force arm restraints have the adjusters like shown,single piece.I just clip one end to Simpson suit and other end to belts.I don't use the part that goes around arm so I think I am still legal?Part #471-4087 adubk at jegs
#327 C/GR
CTRon
Quote from: deep in debt motorsports on February 12, 2018, 01:33:52 PM
Interesting.. have you run bville before with that setup? I have sown in rings in my jacket too an if they will allow this ill get the same ones
maxton 2 club member 205.188mph  A/BFR
loring 2 club member 219.807mph  A/BFR
Wilmington 2 club member 202.702 A/BFR
bonneville 2 club member 225.003 XXF/BGRMR
I'm thinking that clipping on to the "narrowest" part (wrist?) of a floppy suit ain't gonna cut it.
#18
Yep,ran this last year,it clearly states adjusters!!!These are the style they are wanting and doesn't say anything about sewn in being illegal,says,if it is NON-sewn in then must fit tight at smallest part of arm so that means if sewn in must be all good!! I feel rule change is for adjuster only????
#327 C/GR
CTRon
Quote from: Stan Back on February 12, 2018, 06:31:52 PM
The rings are sown into the jacket.
Buamotorsport
Having spent time with Allan from Simpson at Pomona this past weekend there is without doubt confusion as to what is acceptable and what isn't. I know that Simpson are trying to clarify the rule and what is or what isn't acceptable.
Frankie7799
I just bought brand new Simpson arm restraints late last year as my previous ones were out of date. Guess Ill have to look at them when I get home and figure out if they are legal or not
Tman
Quote from: Frankie7799 on February 13, 2018, 01:33:04 PM
We are looking into it as well
QikNip
I got tired of trying to figure it out, so I ordered a set yesterday from Deist. Not worth $40 to waste any more time! :dhorse: :-D
Rick
138.0 G/CPRO 4/18 Arkansas Mile Challenge Record
145.632 G/CPRO 8/17 Bonneville Record
149.825 G/CPRO 8/18 Bonneville Record
142.443 G/CPRO 9/20 Loring 1.0 Mile Record
156.343 G/CPRO 9/20 Loring 1.5 Mile Record
thundersalt
Just Recieved
916 REMR
El Mirage 200 MPH Club
Pegasus Racing actually has the specified adjustment plate available for 1.75 to 2 inch straps. Duke and I are going to look at his Simpson arm restraints and see if they could be converted to this type of adjuster, would that void any type of warrentee or the SCTA new rule? We also considered having some water jet cut from some stainless plate to the exact strap width. Going with the DJ stuff is probably the best way.
I know that the SCTA does not make these type of changes without a good reason, have they seen failures of arm restraints with the welded "D" ring configuration?
Dynoroom
Quote from: Rex Schimmer on February 16, 2018, 12:24:43 PM
Yes, more than 1
Ron Gibson
I think we need way more clarification of what is actually required for hardware and where. My Pyrotect restraints have a large welded D- ring on the end of the strap that the seat belt latch goes through,  a pair of small D rings to tighten the arm bands, and a one piece "ADJUSTER" on the restraint strap between the arm and the belt. I have no idea if this is legal for SCTA.
Ron
Quote from: Dynoroom on February 16, 2018, 01:00:14 PM
Yes, more than 1
Lee Kennedy kept ours after the incident... although they did not fail, he sent them to DJ for inspection... He also mentioned they had "several d ring failures" in arm restraints and was working on a rule change.... Left my arm restraints with DJ to be put in compliance with the new rules...  Must be about time to call them again and see if they are ready
revolutionary
Guess my new -20 suit with sewn in D-rings is not legal now. Rad
Breaking Wind #9614
  ECTA Record AA/BGALT 214.8
