traction and weight door car
Started by ulrace, September 25, 2018, 10:46:33 AM
Dynoroom
Quote from: Leadfoot on September 27, 2018, 08:54:03 PM
What's this ? A 12 bolt center section or complete rear ended ? Strange makes a 12 bolt center section for the ford 9 inch.
You will find that the Strange 12 bolt center section will not accept a series III carrier which you will need for the gear you will need.
8300 rpm for a mile is doable with Cup state of the art engine hardware but you would be better served running a lower rpm unless you have the $$$ to chase the engine package.
We went 307 MPH @ 7300 RPM with a 12 bolt using a hard to get today 2.13:1 ring & pinion. The car weighed 5200 lbs.
One other thing, your 29.4" tire has about 92" of roll out... sitting still.
Adding verbiage to make the site think its a new post, I hate that...
jl222
Quote from: ulrace on September 26, 2018, 05:57:02 PM
have frontrunners ; 26" (ford 9" 2,47 ratio. 60lbs in tires.
4 link with top bar adjustment.
bob
Alston has a book explaining 4 ling settings, we run a long and low instant  center to reduce shock to tires.
  I don't know how many revs you need to get for the record [ info in laptop and dream wheel in shop]
But if a problem, a gearvendor overdrive would help.
ulrace
Hey Sparky; trying to understand your 4% more "tractive effort" comment. Are you saying that a taller gear will do that or just the lighter ring and pinion. The salt is new to me and I find a lot of counter intuitive things. Just learning. Also I am thinking a taller tire is better even if takes car out of best rpm range. Power is not the problem for me right now, just traction.  I will make sure I have 1000 lbs more weight in the car next time.
bob
