Frontal Area / Cd numbers
Started by Simspeed, April 19, 2019, 06:03:32 AM
Simspeed
#120
Good advice Eddie. I'm sorry if I don't give proper recognition to those that have done it, its because I just don't know who most of you are relative to your accomplishments.  Hoping to learn more about you all.  :-)
Quote from: Eddieschopshop on May 02, 2019, 08:51:28 PM
There are very few that have gone really fast,,  you have several here chiming in.  There are those that theorize and those that do, take advantage of those that have!
:cheers: :cheers: :cheers: :cheers: 8-)
Simspeed
Quote from: kiwi belly tank on May 03, 2019, 11:52:18 AM
That is what I'm hoping to do Sid...thanks  :-)
John Burk
"Well I like the idea of increasing the tail fin area to help out with the stability.  Not much frontal area to a 1" fin.  I've emailed Woody hoping to hear back from him before long.  Thanks."
I didn't phrase it well enough . I meant physically tall like 18" long and 5 ft tall so in a yaw when tire friction tries to roll the car outward the air pressure on the tail fin won't let it . I remember tall tail fin on Joe Law's lakester allowed a spin instead of a crash at Elmo .
Simspeed
Quote from: John Burk on May 03, 2019, 10:20:33 PM
5' on a 30" high car looks pretty tall John.  But whatever works is good with me. At least we have something to move the Cp around with. Woody got back with me and fortunately for him he's got a lot of work going on.  I will likely get these concept body analysis done elsewhere and hopefully work with Woody later down the road for a more detailed look at the car as a whole.  Drawing up another body and chassis with a drooped nose for a CFD comparison of the two.  Frontal area is almost identical for both so Cd is what I'm looking to compare.  Thanks...
It almost always boils down to TIME-TREASURE-TALENT
robfrey
Don't forget about "Passion " Sparky.
Key motivating factor.
Rob Freyvogel
#496
AA/BFS
Quote from: SPARKY on May 04, 2019, 08:09:07 AM
Quote from: robfrey on May 04, 2019, 08:10:39 AM
And you both missed the one we rely on the most.... Dumb Luck  :roll:  :cheers:
tallguy
Quote from: Stainless1 on May 04, 2019, 08:16:46 PM
We shouldn't be relying much on Dumb Luck -- at least regarding safety.  My 2 cents' worth:  use suspension, and have each steering wheel
pivot about its own pin.  Build economically, and work gradually toward higher speeds, over many years.  Good luck.
Simspeed
I've studied everyone's comments and suggestions and determined I had no ability to optimize Cg and Cp with the previous design.  So I decided to take a different approach and repackage everything into a front engine layout as shown in the attachments.  I've moved the drive wheels to the rear and designed single wheel suspension steering using a hub center mechanism with dual shocks and hydraulic steering control.
I designed a 50 lb refrigerant intercooler for the intake charge, oil and methanol at the front, and a 30 lb intercooler system for the drive motors and electric controllers at the rear.  Those systems will use digital thermostatic expansion valves to meter refrigerant delivery through control channels in the engine management system.  Low pressure heated refrigerant will bleed off from the expansion lines after passing through the connected intercooler tanks.
Simspeed
#130
I was able to get 20° of steering lock to lock with the single front wheel vs. 6° for the dual front wheel chassis layout...big improvement.  Do you know anyone else that's using manual hydraulic steering?  Boats use it well, I'm figuring it should work well here too.  Any thoughts?
Simspeed
More attachments
Simspeed
#132
This new body design actually has a smaller frontal area than my previous one.  Lots of detail missing such as the canopy bracing and tin work but this is just an exercise to see if I can get everything to fit.  Any observations?  Thanks...
Simspeed
#133
Perspectives
I'm impressed!
Listening in to a bunch of folks that've been there and done that.
We don't get that all the time here.
(I'm way out of comprehending all of this, but I sure can see and respect a lot of guys who have been there – and someone's listening!)
