Project RailGun - Introduction
Started by mgriffiths, February 11, 2021, 10:44:42 AM
mgriffiths
The plywood installed.
mgriffiths
The polyester cloth stretched over the buck
mgriffiths
After applying the resin.
mgriffiths
I'll do another layer of cloth, then maybe fiberglass if needed.
Cheers, Mike
mgriffiths
A couple more pics of the body work progress. Here is the rear cover birdcage and mesh, ready for some fiberglass and gelcoat-
mgriffiths
And with the front (ready for smoothing and hole cutting)
mgriffiths
Getting closer - The front and rear body shells are almost finished, but are ready to be properly mounted to the bike - Then I can start cutting out holes for cooling, exhaust, handle bars, etc.
Cheers, Mike
edinlr
Are we running at Speedweek, I thought I heard Slim mention you on his broadcast?
sabat
He is, I heard one pass around 110-120mph  :cheers:
mgriffiths
We had to abort a few runs due to new bike problems (Shifter interference, throttle coupler), but I was able to get 2 clean runs before we had to leave. Unfortunately for one pass I ran too low a gear and the other pass I ran too high a gear, so I never reached max speed for the bike. I topped out at 123 MPH (against the 125 record). Very long lines on courses 1 and 2.
Cheers, Mike
mgriffiths
Start Line, Speed Week 2021
thefrenchowl
 :-D Have a good time, wish I was there!!!
(My 1st time on the Salt Flats was exactly 10 years ago...)
Patrick
