Automatic Transmissions
Started by ggl205, May 21, 2021, 01:57:01 PM
desotoman
Quote from: ggl205 on May 30, 2021, 03:40:04 PM
The 4L80 is the T400 with an overdrive gear making it a 4-speed. Just trying to find out if they run the 3-speed or 4-speed version.
Quote from: kiwi belly tank on May 30, 2021, 04:00:22 PM
The 4L80 is not a 400 with an OD. It has many similarities & internal components from the 400 but it is incorrect to call it a 400 with an O/D so don't confuse yourself there John. They are different animals.
John,
I don't know where you are getting your information but Sid is completely correct on this subject. There was never a Turbo 400 made with an overdrive from the factory with the turbo 400 name. The later 4L80 may share some similarities, but it is a different transmission even if is shares some of the same parts. When anyone talks Turbo 400 they are talking about a 3 speed transmission that is not computer controlled. When people talk about a 4L80 they are talking about a 4 speed transmission that the 4th gear is an overdrive and it was designed to be used with a computer of some sort.
I hope this explains where I am coming from on my question, and why I am confused on your question about how many gears the Waters Roadster has.
ggl205
I think I need a course in better communications. Originally, all I was trying to say was that the T400 and the 4L80E transmissions share the same 3-speed gear components. This is discussed in just about every technical article I have read on the subject. I never once said the T400 ever had an overdrive only that if one were needed to attain a certain mph, the 4L with an overdrive gear, would be the transmission of choice. Most certainly, there are differences between a T400 and the 4L but all I was looking at was which transmission is used in the Waters roadster. Very sorry for all the confusion on my part. I was just trying to get some additional clarity on the exact transmission the Waters team is using. From this discussion, it appears it is a Kilgore T400 with modifications.
kiwi belly tank
Quote from: Stainless1 on May 31, 2021, 08:35:25 AM
Detour alert  :-o
Sid... redundant relays??? are you adding failure points or concerned that the relays are not reliable enough that you are giving parallel paths.  I trust you are using the totally sealed Delphi relays... not those kinda sealed parts store ones.
There's 19 relays in total & they're all quality German Bosch items.
The redundancy is in the direct-O/D control since there is one in front of each pinion & having one shift & the other not shift would be catastrophic. 2nd gear O/D is about 100mph faster than 3rd direct due to the O/D ratio & I have the shift set up so if I need to I can shift 1st-2nd-3rd-2nd O/D- 3rd O/D or skip 3rd & go 1st-2nd-2nd O/D-3rd O/D.
There's 6 electric oil pumps feeding two diff's, O/D's & T-cases, 2 electric water pumps, dual crank trigger ignition-EFI systems, blah blah blah, you get the picture. A smarter man wouldn't have started building this much liner alone.
kiwi belly tank
Yes John, they have a 3 speed no O/D.
A gearing calculator will tell you what you need & I'm sure you've already been there.
You ran a pretty small tire with the little Ford engine, do you plan to stay with that?
ggl205
#49
The tire I ran in 2017 was a 25? front runner. The tire I have on the car now is a 22.5? M/T Bonneville. Looks like I will need something close to a 26? rear tire if I use the 2JZ engine and T400 transmission. Might be able to go smaller than 26? if I can get a lower (numerically) final drive gear than 2.56.
JR529
We run the 3 speed T400 with a ballistic trans blanket.
kiwi belly tank
Quote from: ggl205 on May 31, 2021, 12:44:57 PM
I presume your idea of going to a smaller tire is based on less drag, is that correct?
That actually creates more negatives than positives.
The smaller the tire the less traction it has & while you're talking about moderate power from a 2JZ at this time, that's still a bunch & you know down the road just like everybody else you're going to set it on kill.
Secondly, it takes more power to turn a big gear than it does to turn a big tire so you really don't want to be reducing tire size.
8k rpm is probably a good number for a 2JZ, 26" tire, 2.56 gear & .75 od gives you 322 mph.
If you're planning a 10 bolt you can move up to a 2.41 gear & come up with 342 mph.
Or a 2.14 that gets you 385 on paper.
All that driveline stuff is simple & cheap.
ggl205
Sid, the 22.5 inch tire was chosen specifically for the 2 liter G-class engine and Hewland 5-speed. With 350+ HP on tap and 10,500 RPM, I potentially can make a theoretical 250 MPH with power to spare. Realistically, I am looking for around 230 MPH if all goes well. Stainless and Bockscar 2.0 are capable of that speed too so it ought to be a great shootout for top honors. My car is prepared (or soon will be) for G-class competition for as long as the engine is available to me. All this discussion about automatic transmissions is preparation for if and when I move to Blown F-class competition. Anybody want to partner and get a blue hat?
With a 26 inch tire, you hit my number of 322 MPH with the 2JZ, .75 overdrive and 2.56 final but if I use the T400, I will have to make up for lack of overdrive with a numerically lower third member R&P. My car recorded a .24 Cd in the tunnel and that data can be manipulated to determine power required to make any given MPH number I put in. At 322 MPH, data says I still have considerably more power available but you and I both know about the theoretical at Bonneville. Darn near impossible to reach. If I can get close to 322 with the 2JZ, I will be the happiest guy on the salt.
kiwi belly tank
The highest ratio 10 bolt gears are the 2.14 (actual ratio 2.136). With a 1-1 trans (no OD) you could get there with that gear on a 28" tire with 8300 rpm, on paper! :-D
love those 2.14 Ebay specials with Toreson diffs
you can buy pump drives for T400s not so for 4l80E you will have to make them.
1leg
Jerry
SDRC Member since 2013
Alternate driver 832 roadster
racergeo
  Came across the story on a record holding street radial drag race 240 SX. Runs 6.60 @ 215mph and makes 2200hp. Transmission is a turbo 400. I know guys running in the 10's with near stock. Shift kit, 34 element sprag, good clutches. Car is called White Rice. Check it out :lol:
ggl205
Holy smokes! That thing is a beast!
ggl205
One more thing to add into the mix. I was told it is possible to direct drive a Th400 to the engine (didn?t say how) and push off in neutral. Get the car up to 30 mph and snick it into first gear. Now, this sounds like a good idea and eliminates the torque converter. Any atrocious downsides?
