Hello
Started by biketoc, April 13, 2007, 04:35:15 PM
biketoc
the wheel size is 13 inch rim's I run 130  mm Michelin pilots
tonight I hit 63 mph on flat ground with 70 cc motor stock body with mirrors .
:-D
It ain't bragging if you can show us the timing slip.  Got one?
No offense intended -- but speedometer readings are notoriously unreliable.  Okay for relative changes -- not for absolute values.
sockjohn
#32
Quote from: Seldom Seen Slim on April 19, 2007, 06:30:33 AM
Slim,
Agree with you 100% on the speedo, but I have no doubts about a scooter capable of hitting this kind of speed.  There are local guys pushing 80 on these, and IIRC this is pretty much the motor in the Buddfab stremaliner.  Pretty sure the local guys are getting their fuel at the airport however :)
The thing I always wonder is how they reach these speeds with a CVT, hard if not impossible to regear a CVT, unless they are just able to get the motor reved up that much more than stock.
Biketoc,
My rulebook arrived just yesterday, so you may want to verify the information, but have to have 15" or larger wheels unless it's a streamliner or sidecar.  Also, if you go over 70, will need at least H rated tires.  This has caused me some grief in the planning to say the least.
Or Production, or running at Bub...  :-o  :wink:
bak189
Bring your scooter to the BUB Speed Trials.....and run with the other 100mph scooters........................
biketoc
I am bragging  :evil:If I had a timing slip if would be from the cops.
I just put the motor together Sunday and broke it in all week. I held just a touch over 9000 rpm@62 but I think a little off the top of my cylinder will put me closer to 9500 .My speedo is dead on accurate but dose not mean a thing
I want it in two directions timed to 1 /100th of a second @5000 feet.
Rick Roberts
Bring the bike to Maxton and get a few runs. I agree with Slim, stock speedo is way off. At 150 indicated on my Busa I was timed at 135. Wheel size might be a problem passing tech, but Jon's 35 mph 600cc passed and won class at the ECTA / Super Street Bike top speed challenge so maybe it won't be a problem . Best of luck.
ECTA 200 Club
biketoc
Quote from: Rick Roberts on April 19, 2007, 05:56:04 PM
my vfr 800 the speedo is off by mph I know because I have a bicycle speedo hooked up to my front wheel . I use the speedo to map out bicycle rides  making  direction sheets for rides over 100 miles or more I my mileage from point to point is off I hear about it from the cyclist . I only want to get a few runs in and get an official slip to show how fast a modified sr 50 will go. I do not dream of breaking records .that takes money.
Rick Roberts
You might be surprised about the records. There are a lot of open classes at Maxton (no existing record)  that your bike might fit in. Get a rule book and make sure your machine will pass tech, then check out the classes you can run. There is a very good chance you will find more than one open record running a 50cc 2 stroke. Wheel size may be a problem with tech, but if so, you can always run time only to get an official time slip as long as the bike can pass the safety rules.
ECTA 200 Club
biketoc
Quote from: Rick Roberts on April 19, 2007, 06:43:55 PM
thank you all for the information. I am coming down to Maxton in September. I need to get over the last round of engine rebuild expense then I will be ok . In the mean time I will get my rule book.
Just a quick question .Can I use a bone stock 2006 vfr800 to make a license pass ? or do I need to remove the stands and safety wire the whole bike?I can ride down on that and make a license run .
biketoc
Quote from: sockjohn on April 19, 2007, 10:37:13 AM
Slim,
Biketoc,
the tires I have are not speed rated but they are the best scooter tires available and I do not think this one will do 70mph  or above
realistically I am looking at speed around 60 +/- 5mph
Dan Stokes
I've scanned this photo carefully, blown it up, etc, and have failed to find "The Good Looking One".  Please send more data.
Dan
Quote from: Speed Limit 1000 on April 14, 2007, 09:08:04 PM
Quote from: 1212FBGS on April 14, 2007, 05:55:37 PM
Noonan is the bald guy in the center... man that dude in the green leathers looks like he is in the process of taking a dump in his leathers :-D
kent
I think that photo was taken after his trip to the lake at Bonneville. :evil:And everyone knows that Noonan is the good looking one. :-P John you can also apply my check to our next order. :-D
Wilmington, NC - by the sea
ECTA idiot, Bonneville volunteer
JackD
Quote from: Dan Stokes on April 27, 2007, 11:51:14 AM
Dan
It's all relative.
You have to understand they have been away from home and with each other for awhile.
Dan Stokes
Is this a Brokeback Mountain thing?  I still think Trillium or Da Murph (or any of the other ladies) is "The Good Looking One"!
Quote from: JackD on April 27, 2007, 12:59:25 PM
Dan
It's all relative.
JackD
Quote from: Dan Stokes on April 27, 2007, 05:46:29 PM
Dan
There seems to be hope for you.
It's all relative.
