my 1000cc APS/BG project.
Started by panchop, May 28, 2007, 06:38:17 PM
oz
what kinda pressures are you running, I have been told and read that tyres are running 50-60-70 psi on the salt is there a sound basis for this as a softer tyre will get more traction to a point I dont mean run it flat but 35-40psi and it will have a better chance of getting a grip,Are the pressures so high for a reason keeping them on the rim coz they get too hot/distortion at speed what is the theory.
ol38y
#31
 :-D A trick I learned from thr bicycle guys was. The harder the tire the less rolling ressistance. As always you would have to adjust that to circumstances, dirt or salt. So, eventually you have to know your bike and what it likes compared to the conditions. Horsepower, frontal area and drag all play a part in your optimum performance. As a newbie, it's a crap shoot till you find what your bikelikes...   but  I dunno. just my 2c
Your mileage may vary!!!!!!!  right Jack!
I remember back in the 70's we'd drag a set of Pirellies off thr roof of the shop cuz they had been sufficiantely hardeded. We'd usually leave them on te roof for about a month and they worked great, but times are changing. Also, back then my crew chief whould put 8 # of air in the tires, which is unheard of now. But, the tires hooked up and we did our job, with good finishes. And, I still have a number of those tires and they still work against the new Goodyears. So, I dunno, I just did what I was told. And had a lot of funnnnnnn.
This is longwinded but, I think you just have to find what works for you. But, I also don't think anyone here will let you run off the deep end without your floaties... Well, except maybe Kent..... :-D
Larry Cason
2010 BUB 1350 M-PG record
oz
I know what you mean about times a changing we used to run around on rigid framed chops old gsxr motors good for 150s with 20-25psi in the back just to take out some of the bumps never had any bother with them but I wouldnt dream of doing that on salt
1212FBGS
50#s......yep you just keep doin that :-D
kent
panchop
#34
well i have added a zx 11 front end, and made some body modifications. I also changed over to an external wastegate. I will see how thhat works as i could not control the boost last year.  I had much more planned but alas life got in the way this year. something i am sure you are all familiar with.
I cut away most of the body as i couldn't get my legs in out off the breeze. i think it will work better. only one way to tell i guess.
looking forward to seeing some of you in sept at BUBs. Hopefully i won't be thrashing the whole time this year and i will get a chance to meet a couple of people.
John Noonan
Quote from: panchop on June 28, 2008, 09:21:47 PM
You painted the frame Green Greg?
J
panchop
well it is a kawi john. ( OK cheap duplicolor mopar grabber green) I wanted a light color to show cracks but i didn't want to spend big money on powder coating. If i can hit a good number this year i plan on building a whole new frame . how have you been?
isiahstites
John Noonan
Quote from: panchop on June 28, 2008, 09:31:18 PM
Greg,
Been good and just doing the same old stuff, see you in Bonne :mrgreen:
