Getting ready for Bonneville(rebuild)
Started by bvillercr, June 26, 2007, 06:18:10 PM
Tried spinning at both -- sure prefer Bonneville.  Clean and silent.  Won't run a posi again, tho.  Once was enuf.
jl222
2283 Goodyear front tires bought today in Vegas and should be delivered tomorrow.
  ProCharger Intercooler should be here next week. Hope its exactly the same so all the pipes fit.
jl222
#2102
Quote from: jl222 on February 26, 2015, 05:06:18 PM
 Tires delivered today at 9:20 this morning :-D Opened gate early but not expecting UPS until after 5pm.
 Heard a horn honk and an unmarked white mini van outside, driver says company was OnTrack?
  Going to put Tires in garbage bag [ contain smell ] then in bottom of linen closet, mount just before Bville
jl222
  Intercooler arrived by FedX. All plumbing will hook right up :cheers:
  They made the top and bottom angle steeper but everything else the same.
  Feeling stupid and panicked for a while though. Took it out of box, measuring every thing Then noticed no outlet for water, damn they put them on the bottom, crap I don't like that the water will never get to top of intercooler and a bitch to plumb :x
  Then I turned it over. I had it upside down :roll:  :-D
Captthundarr
Some times things get clearer outside the box.... :-D
bvillercr
I haven't been on here in a while, glad I stopped buy.  I hadn't heard that the inter cooler came in. :-P. lol
bvillercr
Drill and taping the inter cooler for bracing and sensors.
sabat
Egads that looks like the furnace in my house.
jl222
Quote from: sabat on May 21, 2015, 06:21:35 AM
  Just Home Depot assemble yourself cabinets and Formica plastic laminate counter tops [ about $80 per 8' section and around $100 per cabinet]
         JL222  :cheers:
jl222
Quote from: bvillercr on May 05, 2015, 07:34:47 PM
We need to cut a hole on top and weld temp sensor plate from old intercooler and weld tabs on that connect bar
that insures that blower tubes stay connected.
New Miller 200 muti welder being shipped will post pics.
  Installed new blower pulleys and belt, gas tank and fuel lines and fabricated new inner spill plates and most of the angle brackets Sunday and Monday. Troy took pics, should post.
jl222
  Finished mounting new plates today just need to uninstall, sand sharp edges and paint.
Ordered longer fire bottle cables Friday from www.controlcables.com [ rule book add ] should be here soon.
  Need to weld tabs on intercooler for blower tube restraints and plate with !/2'' pipe thread on top of cooler for temp sensor.
  Getting close to fireup :-D
  Got to pull right rear hub on trailer and try to figure out why we blew 3 tires there last last year.
1 after Bville, trailer empty going about 50 mph hub never feels warmer than others?
  Think I'll go down to the 4 lane and have Troy look from another car and see if its a balance problem 1st.
  Anyhow we have 4 new tires and 4 spares now :-o
bvillercr
Some long over due photos!!
Cutting the stabilizers
Cut now a lot of fine shaping before mounting!
Two views of both mounted.  Like JL said above time to take them off and sand the sharp edges down and paint.
bvillercr
We are making a new push button fire bottle deployment system, here is what the old one looks like.
The new one will extend out further making it easier to deploy.
We are still waiting for the new lines and will get rid of all the sharp edges once we get the lines fitted.
