Getting ready for Bonneville(rebuild)
Started by bvillercr, June 26, 2007, 06:18:10 PM
You might look in the McMaster Carr catalog they have several non contact tach set ups.
bvillercr
We worked on our spill plates today.  We had some braces to make, drill, and bend to work correctly.  The first photo shows that we have the spill plate close to 90 degrees and that we needed to cut the top down a little.  It measured a bit over 8 inches.
Now the spill plates painted and ready to put on tomorrow, plus we need to make a new push bar for the car.
bvillercr
Got some things done on Sunday.  We tacked the pushbar together and in place and we finished the spill plates on the spoiler.
bvillercr
Today we replaced both pilot chutes with two new ones.  They are much stiffer and the design looks much improved than twenty years ago. :-D  We also finished the push bar and got it back together, just need to get a shorter bolt going through the wheel.  Another improvement was to our seat belt connection on our window net.  We were going to start it today but our batteries and battery charger was not up to snuff.  Only a couple pictures today. :cheers:
bvillercr
We fixed a few gremlins today and fired her up.  Seems like something isn't going quite right, we are ahead of the game.  The car started really easily and after we warmed it up we adjusted the valves and buttoned her up.  Only a couple things to do before the May meet, and we should have it loaded the weekend before. :-o  I took a video of the warm up, because I'm nutty like that.  I will post in a couple of days. :cheers:
GH
John, Troy, what kind of primer did you apply on the aluminum spoiler pieces before painting? I'm thinking about painting my spoiler also.
Hey Gary, you can get direct to metal stuff that works well for canodizing aluminum....  and steel...  :-D
jl222
Quote from: GH on April 29, 2009, 06:00:45 AM
  Brake clean :-D
bvillercr
We had our share of problems at Bonneville and El Mirage this year.  One problem was that our right side plexi glass light cover flew off at speed week.  We temporarily fixed it and ran the rest of the week and El Mirage with it.  So now we have time to do some cosmetic work on the car.
We took the old light cover off and some old El Mirage dust was hiding behind them.  I cleaned it before the picture. :-D
Our aluminum pieces fit nicely.
Now complete with paint.  Just need to fill around the covers with black silicone.
mkilger
bvillercr, are you ready for elmo?  cant wait to see your car again, it's starting to grow on me.  :-D
bvillercr
Yes, need to paint part of the hood and maybe replace a few Dzut fasteners and pack and load the car.  should be loaded and ready to go this Saturday. :cheers:
bvillercr
We got the car loaded up for El Mirage today, and we needed to take a picture and send it in with our Bonneville entry.  I took a few, tell me which ones look the best.  Thanks :cheers:
isiahstites
The last one.........see you at El Mirage!
