Water against detonation with Nitrous
Started by oz, December 27, 2007, 01:40:56 AM
2fast4u2c
Quote from: 1212FBGS on December 31, 2007, 03:00:36 PM
it also does wonderfull things for ya Guy... hey were ya been..... and why didnt ya come down last time you were out.... ya butthead... :-D.
kent
John tried to get me out there, but my plane flight was too close for comfort.  I just knew I would get delayed and miss my flight if I came down there from LA.  But...You haven't called, no flowers, no dancing girls, no letters or cards, I'm hurt.
When you get a few minutes to spare, give me a call if you can.
Guy
300mph or Bust in 1 mile!!!
Tiger Racing
1212FBGS
Ok apology accepted....We dont let the dancin girls get to far away from the shop.....I still love ya man.....
Kent
oz
hey Kent did you get PM with Morini details?
HotRudyRod
Well getting back to the original topic, water or alki injection does make wonders for detonation suppresion, cooling and octane boosting on forced induction engines. Now water/alki and nitrous hasnt been as widely researched and the people that have arent talking about it, i've talked to Rodney from Alcohol Injections Systems about it and this is part of what he answered me:
"Hi Rudy,
First of all let me say, running water methanol injection with nitrous is perfectly fine. We actually sell many systems to strictly nitrous users as it offers the benefit of increased octane while stabilizing the combustion process.  This allows users to then run much less ignition retard while adding some extra safety to the motor at the same time."
The cons i see with running this kind of set up in N/A nitroused engine & water/alki injection would be tunning as it would run very rich since these systems are normally setted up for boost not nitrous and would need extensive tunning and scanning logging tools to get the proper A/F ratio when on the gas.
Try checking out all the alcohol/water injection at the following link:   http://www.alcoholinjectionsystems.com/Tech-Articles/t7/articles.html
Rudy.
oz
uglydog56
We tried on my brother's 55 drag car.  400 sbc with a baby blower and a cheater plate.  It ran about .5 faster on the water/meth.  It ran about 1.2 faster on the 150 shot, no water/meth.  Next we tried both, it went slower on both than it did with neither.  So we put in the 250 jets to do some "real intercooling" and got her in the 10's.  Our theory was the cold temps of the nitrous don't let the methanol give up it's latent heat of vaporization, and we were drowning out the motor.  Maybe we should have dialed back the water after reading the previous posts.
NathanStewart
Sorry to dig up such an old post but FYI water alone works great with nitrous injection.  I don't consider something that delivers more power to be a band aid by any means.  While methanol as twice the level of latent heat as gasoline, water has four time the latent heat of methanol.  That means cooler combustion temps during those long hard nitrous assisted pulls between the four and the five mile.  Cooler combustion temps mean you can run more timing and more nitrous to make more power.  Sound good to me.  :mrgreen:
El Mirage 200 MPH Club Member
2fast4u2c
And here all this time I thought I was supposed to inhale before going down the track.  The nitrous goes in the motor?
Tiger Racing
oz
#38
Its Acually strange this topic should crop up again i was thinking about it the other day,The ideaI had goes something like this a three branch fogger jet with room for three jets,A container that can be filled with the water and sealed,A balloon of some description maybe one used in a nitrogen gas shock or piston on top or in the water,and a branch of the N2O after the solenoid to Inflate Ballon or push piston ,Fire the Nitrous the water is pushed into the jet at high pressure and can be regulated at the jet without the need for another pump.I aint got time to do it for this year but i do think that if I had more time and room on the bike it is certainly going to be a big help!
I suppose I better blow the dust of my CAD programes and get crackin eh!
Blue
In spite of the fact that I believe water is a band-aid, I actually favor it for nitrous engines.  When we boost an engine, we are bringing in atmosphere with the extra oxygen.  So when we combust the extra fuel and oxygen vs. normally aspirated we have more working gas (nitrogen) to absorb the heat.
Not so with Nitrous.  If we add nitrous and the correct amount of fuel we are adding MUCH more heat than working gas to absorb it.  In this case, I would advocate adding water injection specifically to increase the percentage of working gas, and increase cylinder pressure and power for a given amount of heat.
I explained this in more detail on the Ricardo thread, please read it there I can't bring myself to do a cut-and-paste!
rodknox
Quote from: NathanStewart on March 11, 2009, 03:41:35 PM
Can you explain in simple terms what "latent heat" means?
jl222
Quote from: rodknox on October 09, 2009, 09:59:00 AM
  Rodknox
  Latent heat in simple terms means how much heat a liquid requires to change to a gas, for example water evaporating in hot supercharged air will lower the temperture due to its latent heat of evaporation. Thats why supercharged engines using methanol don't need intercoolers because of the greater latent heat of evaporation compared to gasoline.
oz
ah on the subject of supercharging,?I am supercharging the wifes Jawa it is running or should i say will be running methanol with 20% nitro, it is currently running 15-1 which will be too high i imagine what is optimum ratio any idea?
cheers oz
NathanStewart
I have to apologize in advance but I don't know which ratio you're referring to.  AFR?  Compression ratio?  Ratio of 2 stroke oil to gas?  Ratio of old guys to young guys at an SCTA event?  Mind clarifying?
oz
Compression ratio of 15-1
Ooops
and its a four stroke motor!
