Dyno Video - GH's #787 Landspeed Studebaker!
Started by dieselgeek, January 30, 2008, 07:50:31 PM
Quote from: dieselgeek on January 31, 2008, 06:49:45 PM[........................The car is a lot of fun to drive.  He takes it out on the street (yes, it's legal in Missouri!) frequently, I think Sumner has ridden shotgun in it.....-scott
Yep I've ridden in it, but he left the shotgun at home 8-).  He has the suspension set up real tight as is necessary on the salt, but still I could ride in it a long ways ....................... if I was driving :-P .  The really amazing thing about the car besides it's great HP numbers is that even in cold weather, like when I've been there, just turn the key like your family car and it fires right up and idles.  I'll have to give the credit for that too MegaSquirt and Scott's (dieselgeek) tuning abilities and not necessarily in that order,
bvillercr
#16
Yep I've ridden in it, but he left the shotgun at home .  He has the suspension set up real tight as is necessary on the salt, but still I could ride in it a long ways ....................... if I was driving
We felt the rear end of that stude at Bonneville and it felt fairly soft. :-D
Quote from: bvillercr on February 04, 2008, 09:17:40 PM
I think you'd better keep your hands off of other cars rear-ends  :lol:, well maybe we would let you feel Hooley's rear-end, I mean his Stude's rear-end if you were nice about it  :-D,
P.S. Kind of sounds like a line from American Graffiti...........
bvillercr
I like the soft ones, try to stay away from the hard ones. :-o
Quote from: Stainless1 on February 05, 2008, 08:43:56 AM
You boys need a cold shower....  :roll:
So be honest with us what is your preference, soft, hard or maybe firm  :-P
It's nice getting old you don't give a shi............. any more,
Here is the Montana answer...
Ewes not fat... Ewes just fluffy.... :-D  :-D  :-D  :-D  :roll:
GH
We had a very sucessful dyno session. My thanks go out to Mike C, Scott, Mike H and Kyle with the video camera and Tom who has the dyno. I think the 800 mile trip was worth it. We towed home in the snow all the way, temps in the single digits and when we got home and winched the car off the trailer, scraped the ice off the windshield, flipped the ignition on, hit the starter button, she fired right up. This efi is great stuff.
GH
Mike Collison and myself took both cars (#1950 & #787) to the Hot Rod Power Tour (Springfield, MO only). We had a great time visiting with many people, you can see photos on Hot Rod.com, day 2 photos. See you all on the salt in August.
GH
I wrapped the headers with some more wrap, adjusted valve lash, changed oil and filter, installed new spark plugs, greased cluch and shift linkage , installed good rear tires and lubed the chute release cable. All that's left to do is drain the gas out of it leaving just enough to start it and back out of the shop and run up on the trailer. We leave two weeks from this Friday morning.
jl222
Quote from: GH on July 30, 2008, 07:46:13 AM
    Hi Gary
   Now i'm really jealous. Break that record and get in the 2 club.
   Will you be able to turn up the power if needed?
        Good luck and see you at the real dyno JL222
GH
JL, I can up the boost to approximately 16 psi for more power is needed. I will run the 10 psi springs in the wastegates first and hope I can go fast enough. As you know the hard part is mashing on the loud pedal hard enough to go fast without spinning the rear tires too much. You guys might not have as much a problem with that with the wide rear tires you run. I would like to visit with your wife about the Hart genology. Cya
GH
Well, we arrived here in Evanston Wyoming this afternoon about 6:00 oclock. Will leave for the salt about 7:00 in the morning, should arrive on the salt about 11:00 AM, barring any unforseen problems. Cya
jl222
  Hi Gary
Now I'm even more jealous were still home and your almost there.
Trying to get tuned, it doesn't prime well and having problems with to much fuel at idle from big pump.Taking a break today everybodys tired, but they have ideas for Monday
Hope you can break our record big time and get in the 2 club.
     Good luck JL222
