Air Temp Sensor Placement
Started by hombre, February 14, 2008, 01:31:21 PM
dieselgeek
heh    :-D
We share opinions, I'll leave it at that.
So I think the lesson here is, CHECK with the makers of your particular EFI system to see how they handle barometric corrections.  If it's a closed system, strictly using the Ideal Gas Law for corrections, then you should put the temp sensor downstream of any compressors, coolers, etc.
Don't get me started on how the Ideal Gas Law idea does NOT work with open loop realtime baro corrections.   We spent weeks figuring that out.   As it turns out (dave certainly knows this), Volumetric Efficiency changes with increases or decreases in exhaust backpressure.   GM has a white paper on this.
-scott
ddahlgren
hombre
Actually I'm pretty unhappy with what can be done with the stock Keihin ECU. I'm looking to install a MOTEC M400 later this year. Full wide-band fuel control would be a quantum leap.
ddahlgren
Quote from: hombre on March 30, 2008, 07:43:46 AM
Let me know when are ready as I can usually offer LSR racers a break and go to both Spedweek and BUBS...
Dave
hombre
Quote from: ddahlgren on March 30, 2008, 09:23:55 AM
Dave
Dave
As a FNG here, I didn't realize you sold MOTEC products. I've been in touch with MOTEC in NC about the wiring harness. Can you supply this as well? Do you have a business website? If not, how should I contact you?
Thanks
Walt (hombre)
doug odom
Dave has an ad in the SCTA 2008 rule and records book on page 216. His company name is Engine Management Systems.   www.enginemanagementsystems.com
       Doug Odom in big ditch
joea
he is the best I know..........though he primarily
works on the very high end outfits that run things
like 24 hr Lemans/Daytona etc........he has a real
soft spot and passion for LSR folks and their endeavors.....
he understands the ENTIRE engine management realm.........not
just electronics.........when your old job was an engineer developing
cylinder heads for Nascar ya know and understand abit about engine
management..........
Joe :)
hombre
Dave
You've received more recommendations than just the ones above... including mention of your excellent harnesses. I'll be contacting you later this year about putting together a MOTEC ECU for my bike.
Thanks!
Walt
ddahlgren
I do ok LOL Keep me posted on whatever you need... PM me and will send a direct email addy.. I have worked on a ton of bikes and cars that race at Bonneville most very successful as well. In my mind you can not answer the question if you don't know the problem...
Dave
The problem is:  The Earth rotates---the Shadow moves:
ONE must move the source of the shodow--OR--the beer drinkers solution---MOVE THE BEER COOLER after each beer throughout the day to keep it in the SHADE!!!!!!!!!
landracing
HEy dave you should take a couple pictures of a before and after on the harness you are working on right now.
It would speak alot.
Jon
dwarner
Sparky,
That is a good modification of my basic philosophy. Many minds = many solutions.
ddahlgren
And there is nothing I enjoy more than bringing Dan a coldone in impound with a car or bike in tow.. :-D
hombre
Finally got the IAT sensor moved to the intake plenum:
