Simple Subject, Fiberglass
Started by Dynoroom, April 06, 2008, 09:31:17 AM
Ray-Dean
Google fiberglass molds, there is a lot of info that might help you. Good luck on the project, keep us updated. :-D
Ray-Dean
Thanks.
I've spent the last few days reading everything I can find on the subject. I'm just not sure if it would be better to make a plug, mold, then the nose, or if it would be easier to just mod. an existing 'glass nose.
Dakin Engineering
Mod an existing to perfection, then make a mold.
Sam
Former mold maker
Turbo Sportsters since '97
836dstr
Ray-Dean,
Using an existing F/G front end would make the process easier than making a complete mold of the front end plus extension, unless you plan to do some extensive modifications like Sam suggested.
If you use a cross-sectional cut as a contour (such as near the cowl where the panels would be relatively constant) then making a mold and a male part would be relatively (there's that word again) easy. Grafting the 36" section to an existing F/G front end would be a piece of cake!
Post pictures.
